Please read before getting your LS2 tuned
Once your PCM is flashed, you cannot go back, you have to purchase another PCM. Be sure to discuss with your tuner and understand the consequences before you get your PCM tuned. Only LS2edit does this.
I learned the hard way.
In the past, when people screwed up something with, or due to DIY tuning or "professional" aftermarket tuning, sometimes the programming would simply be returned to stock, the car taken back to the dealer, and repaired under warranty if there were any warranty left. I guess GM caught on.
As far as other tuning options, I see advertisements for the Predator. Then there is HP Tuners and EFI Live but the LS2 tuning capabilities for both are in their infancy from what I have read. Version 2.0 of HP Tuners is still not out except to a few tuning shops, and not much heard about EFI Live with regard to LS2 tuning.
When people started making posts about tuning our cars I had a real concern about the ability to go back to stock if it ever became necessary. For many the ideal tuning solution includes among other things the ability to return to stock. Quickly if necessary.
I was also concerned as to the dealer's ability to tell if the ECU programming had ever been altered. If they can, then it could make for warranty issues.
Thanks for the heads up. It will definitely play a role in the decision making process for many here.
Rick
#2 What are the odds the dealer will even check?
Also, say you had the car tuned and developed engine trouble afterwards. Say the engine failed and you went back to the dealer for a new one. He would find out soon enough. Same if your automatic transmission failed following programming to alter your transmission settings. If they installed a new one and attempted to "update" the ECU afterward, they would know.
I believe what he is saying is that if the car should go in to the dealer, for any reason, and they attempt to do any programming updates, they won't be able to. And they will know then that the programming has been altered.
Rick
http://forums.corvetteforum.com/show....php?t=1179368
...I was a Comp Sci major before I switched to Finance/Accounting. I know just enough to be dangerous about flash memory, EPROM's, EEPROM's, ad infinitum. If the LS2edit software is locking us out of the PCM that's on them, not GM.
My previous car was a Volvo S60R. It is a 300hp turbocharged engine with the boost set to 14.0 PSI. Typical practice for Volvo enthusiasts is to flash their ECU (engine control unit) with a new map that is exactly the same as the factory one with two exceptions: 3-4 PSI of extra boost and a slightly richer fuel mixture to compensate for more air being forced in the engine.
Thousands of Volvos do this on a regular basis for 30-50 hp gains.
I had my ECU flashed. Later, I had a Volvo dealership install a downpipe. Some fishy stuff happened, and for some reason the turbo boost never built. I had the ECU set back to stock via complete memory reload to see if that was the problem. The turbo was still running only 3 PSI. Then, the head gasket blew and warped the head... the evidence suggests the dealership messed up my turbo when installing a downpipe, but there was no smoking gun.
Volvo could find via code on the ECU that at some point in time, I reflashed the ECU with aftermarket code. A flash/reflash history was stuck in the RAM and registers of the ECU. I'm an Electrical Engineer and know for a fact this is possible if you pull out the chipboard and work at it for a while. However, Volvo had a diagnostic program to search for codes, and their program alone was designed to look for such devices. They didn't need fancy computer scientists to figure things out.
So considering a new I-5 turbo engine cost 7000 dollars, there was no smoking gun pointing to the true cause of the failure, and Volvo found that at some point I adjusted the code, they denied warranty coverage and blamed the aftermarket ECU. The evidence suggested the Volvo dealership messed up my car at the downpipe install, but again there was no real "smoking gun" to clear me.
After a lengthy fight my car ended up taking a 20,000 dollar depreciation hit, as there was nothing I could do short of investing in a lawyer on a case that I could easily win or lose...
Not sure how the ECU is on the Corvette. On the Volvo, the chip is linked to sensors for everything, thermostat, battery, AF mixture, boost, tons of things and electrical sensors send and receive information from the ECU. My case was an anomaly, nobody ever had a Volvo fail from an aftermarket chip.
Food for thought.
Sorry about your V car.
Drivetrain blows to pieces but you've had the torque management reduced and Chevy finds out? Your bill... that sort of thing. Just know what you're getting in to!
God bless HPtuners
