C6 at Bonneville
Old Oct 10, 2005 | 12:52 PM
aaaaa's Avatar
aaaaa
Default C6 at Bonneville
Two years ago I took my C5 out to the flats for some top speed runs and got 175. It was stock at the time, mn6. With my C6 now 3 weeks old and 1200 miles I figured it was time to see what it would do. The C6 has 50 more horses but it's an automatic. How would it compare?
The temp. was 55. The salt was flooded, looked like a shallow lake so (like last time) I used the 3 mile long access road that dead ends at the raceway. I went up and down the road twice looking for debris, pot holes etc. Some people were there and I had to wait for them to leave. I started at the entrance to the road so I'd be heading toward the dead end ( no chance of surprises). I made two runs. The first run topped out at 168. The second run was 170. It took about a mile to get to 160 and another mile to reach 170. I kept the pedal on the floor but the HUD showed 170,169,170,169 etc.
Now to do some mods.
Old Oct 10, 2005 | 01:09 PM
not08crmanymore's Avatar
not08crmanymore
Default 170...
did you run out of room before the 186ish top speed?nice run in any case!
Old Oct 10, 2005 | 01:25 PM
aaaaa's Avatar
aaaaa
No, I had room but it wasn't accelerating. 170 is tops. I guess the auto has a lower top end.
Old Oct 10, 2005 | 02:43 PM
Brannon's Avatar
Brannon
Someone will correct me if I'm wrong, but I believe the top speed runs were conducted with a MN6 Z51. I believe I read somewhere that it was the only one geared for 186mph.
Old Oct 10, 2005 | 03:14 PM
SHOOTER 49's Avatar
SHOOTER 49
Do you have an A6 or A4? If A4 --what gears--2.73 or 3.15?
Old Oct 10, 2005 | 03:19 PM
cerino2000's Avatar
cerino2000
Yes, top speed quotes were that of a Z51 in 5th gear
Old Oct 10, 2005 | 03:34 PM
aaaaa's Avatar
aaaaa
A4, 3.15 (Z51)
Old Oct 10, 2005 | 04:01 PM
Miaugi's Avatar
Miaugi
A4, 3.15 (Z51)
Were you in D or OD?
Old Oct 10, 2005 | 04:15 PM
Waldo Jones's Avatar
Waldo Jones
8th Gear
A4-3.15.
Attained 165. Was still gaining. I really think it would have reached 175 if I had stayed with it. I was in od. 4400 rpm.
Old Oct 10, 2005 | 04:42 PM
aaaaa's Avatar
aaaaa
OD??? I've got 1,2,3 & D.
I did try 3 but redlined at about 150 and shifted up to D. I didn't notice where the tach. was at 170.
Old Oct 10, 2005 | 05:11 PM
robvuk's Avatar
robvuk
Top speed runs are usually the average of both directions to eliminate wind speed as a factor. A 3 mph breeze at 170 is exponentially against you.
Old Oct 10, 2005 | 05:48 PM
aaaaa's Avatar
aaaaa
Yes. And I only had the speedo which is probably off a percent or two-optimistic?
Old Oct 10, 2005 | 06:01 PM
bj33813's Avatar
bj33813
With all the noise GM has made , tv and in print, about 186...I'm kind of disappointed in 170. I would have thought at least 180.
Old Oct 10, 2005 | 06:08 PM
LS1LT1's Avatar
LS1LT1
Nah that is not bad at all for an auto with so few miles on it, the autos might even be speed limited to only 170 possibly....a well broken in 6 speed will hit 180+ every time I bet.
Next time try folding in both door mirrors as well.
Old Oct 10, 2005 | 06:19 PM
aaaaa's Avatar
aaaaa
Well maybe. I could have increased the pressure in the tires, lowered the car, had less fuel, removed the air filter, disconnected the power steering and alternator etc. but the point was to find the top speed of my stock C6.
BTW it got a little light in the front but never did anything bad and I felt completely in control.
Old Oct 10, 2005 | 06:21 PM
VET4LES's Avatar
VET4LES
Old Oct 11, 2005 | 12:21 AM
CSICKS's Avatar
CSICKS
what kind of trouble could one get into for doing this?
To C6 at Bonneville
Old Oct 11, 2005 | 09:01 AM
bj33813's Avatar
bj33813
I'm surprised you didnt pump up the tires as per the manual tho..what did they say...40psi or so....esp at bonneville. And maybe with the stock gearing instead of 3.15 it might have done more too ?
Old Oct 11, 2005 | 01:26 PM
aaaaa's Avatar
aaaaa
The car might have caught some air and flipped or I might have lost control due to a malfunction (tire, hose, panic ) Aside from that I can't imagine anything going wrong
Old Oct 11, 2005 | 02:28 PM
C6_NITPICKER's Avatar
C6_NITPICKER
I reached 180... 183MPH a couple of weeks ago, I am positive that I could have gotten higher had my wife not started screaming next to me .
