Z51 brake pad adhesive?
Old Oct 15, 2005 | 09:54 AM
Flareside's Avatar
Flareside
Default Z51 brake pad adhesive?
Does anybody know what type of adhesive is used to glue the front Z51 brake pads to the calipers? I've removed mine a few times now, and the adhesive is shot, so I'd like to replace it next time it's apart.
Does the adhesive come with a new pad set?
Old Oct 15, 2005 | 10:26 AM
Steve Germany's Avatar
Steve Germany
It is not adhesive it is an anti-squeal compound and can be found in any automotive parts store.
Old Oct 15, 2005 | 10:31 AM
Flareside's Avatar
Flareside
I already have an assortment of anti squeal compounds, it's nothing like any of them, it's a real adhesive. I have two sets of Z51 brake calipers and pads, and the pads had to be pried off with a screwdriver to remove them on each set.
The Z51 brakes use this adhesive instead of the spring clips used in the C5 (any maybe the standard C6?)
Old Oct 15, 2005 | 10:39 AM
Steve Germany
Kwell! Learn something every day!
Old Oct 15, 2005 | 01:40 PM
VET4LES's Avatar
VET4LES
I have seen them on other cars and have not seen them at auto supply stores although I have not looked for them. You could try the dealer. The one's I have worked with come with the new pads.
Old Oct 16, 2005 | 01:11 AM
ricatthebeach's Avatar
ricatthebeach
Yes, it comes applied to the back of the pad. You remove a piece of blue paper that protects the adhesive before installing the new pad.
Old Oct 16, 2005 | 02:22 AM
SickRick's Avatar
SickRick
Never had to "pry" either the stock Z-51 or the ceramic pads off the caliper pistons. There are "spring clips" that mount in the pad guides, and I believe the front ceramics (not the rears) had a rubber-like sheet that got stuck onto the pads (versus the rears, which I sprayed with anti-squeel stuff).
Rick
Old Oct 16, 2005 | 08:54 AM
Flareside's Avatar
Flareside
That's exactly what I needed to know, thanks!
Old Oct 16, 2005 | 09:05 AM
Flareside's Avatar
Flareside
Rick
Are you sure your car wasn't built on a Monday?
The only spring is the one in the center of the caliper, C5 uses it, C6 Z51 doesn't, they have glue instead. Not sure about the standard C6. The stainless pad guides on each end are used in all cars.
Old Oct 16, 2005 | 09:30 AM
SickRick's Avatar
SickRick
I was referring to the pad guides (reference "spring clips"). When I switched to the ceramic pads, only one set of pads had the "stick on" sheet, the other did not. Coated both front & rear with anti-squeel. The pad guides keep the pads from flopping around - nothing else was used to "attach" the pads to the calipers (glue or otherwise)...
Rick
Old Oct 16, 2005 | 11:17 AM
Flareside's Avatar
Flareside
Rick
Sounds like you're talking about the insulator pads that come attached to other non-factory Z51 pads. The Z51 front pads are definitely glued to the caliper from the factory with no insulators. Unfortunately, it looks like this glue is only available pre-applied to true Z51 pads, so if I want it back it's going to cost $120.
I don't have any squeal yet, but I suspect it's only a matter of time without the adhesive in place. In my experience, aftermarket anti squeal compounds don't last very long if you get the brakes hot.
To Z51 brake pad adhesive?
