C6 corner weights
Old Oct 15, 2005 | 12:43 PM
T Scott P's Avatar
T Scott P
Default C6 corner weights
Does anyone know the approx. corner weights on a Z51 coupe?
Old Oct 16, 2005 | 09:47 AM
haljensen's Avatar
haljensen
My car was checked (but not changed) on 6-3-05.
LF = 850#
RF = 898#
LR = 749#
RR = 754#
50.7% Front, 49.3% Rear With aprx 3 gallons of gas and estimated 15# of misc. junk (tools, books, etc.). Aprx. 3218# net curb weight (no gas)for a Z51 with all options.
Interesting point; the F/R balance was the same with my 170#'s in the car.
Old Oct 16, 2005 | 07:02 PM
T Scott P's Avatar
T Scott P
Interesting the almost 50lbs dif in the front weights.
thanks.
Old Oct 16, 2005 | 07:21 PM
SickRick's Avatar
SickRick
thanks.
Probably sets up the weight distribution of the "average sized" driver...
Rick
Old Oct 16, 2005 | 09:06 PM
haljensen's Avatar
haljensen
thanks.
But very close to balanced with me in the car; 901 LF & 914 RF. my 170# added 51#'s to the LF and only 16#'s to the RF. Maybe if I gained weight it would balance perfect?
Old Oct 16, 2005 | 11:37 PM
HalM's Avatar
HalM
That's pretty darned good for a street car...I just towed the race car up to sears to have it setup for Thunderhill...
Old Oct 17, 2005 | 10:20 AM
MitchAlsup's Avatar
MitchAlsup
LF = 850#
RF = 898#
LR = 749#
RR = 754#
Just a note: You should corner weight your car with your weight sitting in the drivers seat, 1/2 tank of gas, and the tires at hot pressures (typically 40 PSI), and the alignment set to where you will be tracking the car.
Old Oct 17, 2005 | 10:40 AM
haljensen's Avatar
haljensen
I don't track the car so my corner weighting was done as part of my alignment just for my curiosity. Since my car is a daily driver I weighed it at 30#'s tire pressure and weighed it both with and without me in the seat just to see what the change would be. Corner weighting is for front to rear and side to side balance; Since our gas tanks are pretty much centered left to right and front to back I wasn't worried about the balance changing with the amount of gas.
Old Oct 18, 2005 | 01:29 AM
HalM's Avatar
HalM
The 1/2 tank is debatable...sprints will not get you down to a half tank...
To C6 corner weights
