Leaf Spring Nuts ???
Old Oct 17, 2005 | 08:28 AM
baf2000_1's Avatar
baf2000_1
Default Leaf Spring Nuts ???
The bolts that come up through the leaf spring ends do not have bolts on them. Can this be correct?
Old Oct 17, 2005 | 08:48 AM
huskeric's Avatar
huskeric
Yes, this correct.
I just lowered my C6 this weekend and am happy with results....
Old Oct 17, 2005 | 09:29 AM
C6FirstVette's Avatar
C6FirstVette
Should look just like this....
Rear
Front
Michael
Old Oct 17, 2005 | 09:54 AM
HotHonda's Avatar
HotHonda
Rear
Front
Michael
These photos reflect bolt position AFTER lowering- correct? How much
drop did you achieve and how long did it take to settle (approx miles?)
Old Oct 17, 2005 | 10:20 AM
C6FirstVette
Correct...after lowering...initial amound was about 3/4" and then about another 1/4" after couple hunderd miles
Michael
Old Oct 17, 2005 | 11:12 AM
HotHonda's Avatar
HotHonda
Michael
So looking from the underside then there must be a hex head on the other end w/a thick rubber washer/grommett. To get more lowering- that's when you disassemble the suspension and reduce the thickness
of the bushing (or remove it all together).
If the rubber is all removed then the aftermarket bolts you can buy must be exactly the same only no bushing right?
How low will it go front and rear without the rubber washer compared to just backing the standard configuration all the
way.?
Old Oct 17, 2005 | 11:39 AM
Dr. Ground's Avatar
Dr. Ground
Dont take the rubber all the way off the lowering bolt, it will squeek, steel bolt against aluminum. Leave 1/4" rubber attached to the stock bolt for a proper road ride and profile. If you do remove the rubber, Zip Products makes a bushing to protect the aluminum and stop the squeek. This was a lesson learned the hard way. On the front I didnt take any rubber off, just adjusted the stock bolts all the way down.
Old Oct 17, 2005 | 11:41 AM
Stephen B's Avatar
Stephen B
way.?
No, there is a hex on the end of the adjustment bolt (top side above the spring). At the other end of the is a a formed rubber bumper. You can't unscrew that part (the bumper). You can trim it. I would not do away with it entirely as you would have the spring riding directly on the a-arm. Would likely make quite a racket.
The nut that the adjustor moves in is actually integral to the spring.
Old Oct 17, 2005 | 11:45 AM
HotHonda's Avatar
HotHonda
Thanks...picture of your car w/standard bolts in front screwed "down"
tight (or "up" looking from the top) and with the starndard bushing
removed w/ the ZIP bushing in the rear?
Old Oct 17, 2005 | 11:48 AM
baf2000_1's Avatar
baf2000_1
Great pics and details.
Thanks !!
Old Oct 17, 2005 | 12:01 PM
HotHonda's Avatar
HotHonda
The other end is formed rubber bumper AND a hex head I believe.
Old Oct 17, 2005 | 05:27 PM
shopdog's Avatar
shopdog
Front
Michael
The part labeled "strut" is actually a shock absorber. Corvettes don't use struts, the suspension uses full double wishbones instead.
Old Oct 17, 2005 | 07:42 PM
C6FirstVette
Thank you for the clarification...added to the thread
M
Old Oct 18, 2005 | 09:12 AM
05_C6Z51's Avatar
05_C6Z51
After lowering, do you need to have it re-aligned?
Old Oct 18, 2005 | 05:18 PM
C6FirstVette
Lowering with OEM set up only (no after market parts which lower further than the OEM set can do)... for me lowering on the OEM setup (drops about 3/4") dials a bit of negative camber...which I like...gives a better handling characteristic and yes will slightly effect tire wear pattern.
Michael
Old Oct 18, 2005 | 08:41 PM
Steve Snake Driver's Avatar
Steve Snake Driver
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
No. The end of the rubber bumper is flat with no indentation of any sort. The end of the bumper has no flats or hex shape of any kind.
Old Oct 18, 2005 | 09:59 PM
HotHonda's Avatar
HotHonda
I stand corrected...thanks....
To Leaf Spring Nuts ???
