A4 which gear?
Old Oct 20, 2005 | 10:42 PM
The Garage Master's Avatar
The Garage Master
Default A4 which gear?
Ok I am going with the DTE stage II but not sure of gear. I have LG Headers, intake, GM cat back. I will either S/C or head and cam. Doubt the car will every see the track so gear idea's please? I have Z-51 as well. 3.42 3.73 or 4.10? Thanks in advance.
Old Oct 20, 2005 | 11:14 PM
C6 ROLLER's Avatar
C6 ROLLER
I have a procharger with magnaflow exhaust system (503 RWHP)and stock 2.72's for now. It's a blast but looking into the 3.73's. I think 3.90 and 4.10 are just a bit too much. I drive my car everyday (19,000 miles) and like too get on it from light to light. I think these are the gears for me.
Old Oct 21, 2005 | 07:44 AM
1955 BelAir's Avatar
1955 BelAir
Eccentric Member
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07-'08-'09
I am changing my A4 to 3.42 gears. With the change I did to 305/30/19 PS2's on the rear the current ratio changed to 3.23, so with the 3.42 gear set the effective ratio will be 3.50, I don't want to give up anymore RPM's in day to day driving.
Old Oct 21, 2005 | 06:31 PM
C5 then C6's Avatar
C5 then C6
All things equal, you are saying a different tire size will move you from 315 to 323. So in theory, you will pick up a half a tenth, maybe more??? Do they sit on the factory wheels ok?
Old Oct 29, 2005 | 09:17 AM
1955 BelAir
Eccentric Member
They are not mounted on stock wheels, they are on 11" ZO6 rears.
The effective ratio change is due to a smaller circumference on the 305/30's compaired to the 295/35's.
Old Oct 30, 2005 | 10:19 AM
shurite44's Avatar
shurite44
This may be unpopular opinion but if you are not going to track it I would leave in the stock rear end.
To A4 which gear?
