Synthetic Manual Trans Fluid
Old Oct 26, 2005 | 01:39 PM
baf2000_1's Avatar
baf2000_1
Default Synthetic Manual Trans Fluid
Has anyone tried Mobil 1 synthetic trans fluid in the C6 trans? I had a Lotus Turbo that really loved it. Just wondering about the Tremec 6 speed .
Old Oct 26, 2005 | 04:19 PM
radstoy's Avatar
radstoy
I used Amsoil in my C5 tranny and diff. Both showed significant improvement. Tranny shifted much smoother and diff was much quieter especially when turning a sharp corner at slow speeds. Haven't used in my C6 as none of the complaints are noticed.
Old Oct 26, 2005 | 07:46 PM
AU N EGL's Avatar
AU N EGL
Mobil 1 ATF in the MN6 works wonders.
Old Oct 26, 2005 | 08:58 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
The Tremec in the Vette takes a Dexron III ATF fluid. If you get Mobil 1, you should get the Dexron III ATF not the manual transmission fluid.
I use and recommend this: AMSOIL ATF
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Oct 26, 2005 | 09:50 PM
davidfarmer's Avatar
davidfarmer
Mobil One ATF works well, and if you're conserned about heat, use a bottle of Pro Blends ATF additive with it. Basically it is "water weter" for your trans. Tremec suggested back in my early C5 racing days, and I've used it ever since.
Old Oct 27, 2005 | 02:19 AM
LS WON's Avatar
LS WON
Default Was going to sell Mustang GT 5.0 but after putting Redline MTL I didn't
That made alot of difference like night and day. The shifter kept sticking with the regular tranny oil so I went with the more expensive Redline and it couldn't be better so now I can keep it.
To Synthetic Manual Trans Fluid
