Will this work...
Old Oct 28, 2005 | 11:50 AM
SilverGabe's Avatar
SilverGabe
Default Will this work...
Will this CAM 224/228 .581/.588 112 work with Harland Sharp 1.7 Rockers and 1.7 Pushrods?
Old Oct 28, 2005 | 12:39 PM
andreas g.'s Avatar
andreas g.
Default yes it will
I'm running a 224/228 581/588 114LSA's custom grind from A&A corvette. Using stock pushrods 7.4, and stock 1.7 rockers. BTW, If you're not going to increase rocker ratios( 1.75 or1.8 ) why change to an aftermarket rocker. Granted Harland sharps are an excellent product, but you gain nothing. The stock rockers are just fine. I've used them on all my LS1, LS2 motors that were cam modified. No problems. If I were to change ratios to increase lift, then I would use an aftermarket rocker. I prefer Jessel's nonadjustable rocker. Anyway good luck.
Andreas g.
Old Oct 28, 2005 | 12:53 PM
SilverGabe's Avatar
SilverGabe
Thanks for the input. I have a friend that is trying to sell them to me for $350 NIB. He needs some money so I was going to buy them but I searching and its hit or miss with these, I guess some people like them and others dont.
To Will this work...
