LS2 and LS6 heads are the same with the exception of the valves, The LS6 heads have sodium filled exhaust valves and hollow intake valves. Their performance is basically the same so I do not know where you heard LS2 heads were not that great? The 2006 Z06 (LS7) heads will not work for the 402 because the bore is not big enough to accomodate the 2.20" valves. The LS7 heads appear to be outstanding so they would be a good choice if you decided to go with a big bore motor (4.125" Bore). You would also have to switch to the LS7 intake since the intake port shape and location are different.
