Electric Water Pump
Old Nov 9, 2005 | 10:00 PM
The Garage Master's Avatar
The Garage Master
Default Electric Water Pump
Who sell's them and any downside for a daily driver? Upside?
Old Nov 9, 2005 | 10:07 PM
davidfarmer's Avatar
davidfarmer
The mezzier pump should work fine. I tried contacting them for flow rates, etc, as it would be great for racing IF the flow rates are high enough for high hp/rpm continuous use, but they never responded.
The LS2 water pump is the same as teh LS1/LS6 EXCEPT that the thermostat is different.
Old Nov 9, 2005 | 10:32 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Let us know if you make this move and how it works out.
Old Nov 9, 2005 | 11:04 PM
1955 BelAir's Avatar
1955 BelAir
Eccentric Member
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07-'08-'09
http://www.ls1speed.com/catagory.cfm...%20/%20Cooling
Old Nov 10, 2005 | 01:41 PM
davidfarmer
again, no listing of flow rates or performance in heavy applications
Old Nov 11, 2005 | 01:10 AM
tbyrne's Avatar
tbyrne
From: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
We carry the Meziere electric water pumps and I run one on my turbo GTO. I'll see if I can get some flow numbers.
Old Nov 21, 2005 | 12:18 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
The 300 series pump flows 55+ GPM.
Old Nov 21, 2005 | 02:48 PM
Bville-Bud's Avatar
Bville-Bud
please correct me (kindly of course) if I am wrong, but the way I understand it a engine driven water pump doesn't flow much H20 at idle (typically when it is needed in city driving etc.; but flows tons at higway speeds (when plenty of air is moving through the radiator).
I thought this was one of the big positives of a electric pump, you have lots of consistant flow at idle and other RPM's.
Thoughts?
Old Nov 21, 2005 | 03:03 PM
icedancer's Avatar
icedancer
CI 6-7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09
Tag fo sum education
To Electric Water Pump
