I have asked for a picture of the inside install from LKicklight? I saw a Z06 yesterday and they have a completely different fender so they will not just fit without modifications and drilling. The front Z06 will not fit the C6 from what I can see due to the fender design difference on the Z06. The Z06 will not just fit you must cut and trim
Received mine today and have a friend who is triming his for fit. After he is done and the fit is correct I will do mine.
Let me know when yours come in.
Dick
Dick
Are you saying only the rears will fit? I know the fronts are in 2 pieces or sections; part behind the front wheel and part in front of the front wheel. Does this mean that the rear portions or sections of the front wheel well does not fit?
Can you be clear on this: I ordered the front set(the pieces behind the front wheel only) today and now I'm wondering if I should canx the ones ordered for the fronts?
Sounded clear to me "The front Z06 will not fit the C6 from what I can see due to the fender design difference on the Z06."
The front Z06 mudguards do not stick out. The rear of the Z06 front wheel opening isn't flat like the stock C6...its angled toward the rear. The rear fender liner piece for the front is molded to fit flush against this angled portion, effectively covering about an inch or so of the actual fender. Its hard to describe without a picture.
Uhhhhhhhh, this is all well & good however, these are only the REAR moldings, what about the front moldings, behind the front wheel. Remember, the Z06 has a second set of front moldings IN FRONT OF THE FRONT WHEEL." And, what are those molding numbers too?
