Engine Drag Control
Old Nov 14, 2005 | 01:59 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Default Engine Drag Control
While down shifting at a rather high rate of speed, the DIC displayed the following message: "Engine Drag Control Active." I give, what's it mean ? Is this similar to "Ejection seat system activated." Whooo Hooo ! Hold on tight baby ........... You're Very Rapidly.
Old Nov 14, 2005 | 05:11 PM
not08crmanymore's Avatar
not08crmanymore
Default light
ttt-for you.i'd like to know myself.
Old Nov 14, 2005 | 06:50 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
By now I figured one of the tech heads would have jumped on this. I know darn good and well I can't be the only one that has caused the engine to over rev while down shifting after having let the clutch out.
Old Nov 15, 2005 | 01:23 PM
dollarbill's Avatar
dollarbill
Sort of the reverse of Torque Management.
Old Nov 15, 2005 | 01:58 PM
Buffy's Avatar
Buffy
Or Traction Control the other way around.
Downshifting (or lifting one's foot at high RPM) can put a significant load on the rear tires, reducing traction to the point of sliding. This is especially an issue in a high-gee turn, where it's known as lift-throttle oversteer or "chicken out and spin out". The computer opens the throttle a bit to offset this.
The "Ejection Seat Activated" message should only appear if (1) the top is off (coupe) or down (convertible), (2) speed is above 70 MPH and (3) you have pulled the ejection lever on the floor beside the seat. You probably won't have long to read it.
Old Nov 15, 2005 | 04:48 PM
Pipedreams's Avatar
Pipedreams
I have seen it a few times. From the manual
"ENGINE DRAG CONTROL ACTIVE: This message
displays when engine drag control is active. When
driving in a lower gear in rainy, snowy or icy conditions, and then letting up on the accelerator or downshifting, the rear wheels may begin to slip and this message appears. This message will stay on for a few seconds following the engine drag control event"
Old Nov 15, 2005 | 08:36 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Hmmmm; Must go look see. Now only problem is ............ where'd I put the frigg'n manual.
Old Nov 15, 2005 | 08:40 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Wonder if there is a way to disable this function? May be turn off the whole nine yards. I've been driving in Comp mode. 'Sides which, I thought the LS2 edit got rid of all that garbage.
Pipedreams's Avatar
Pipedreams
Click link for one online
Old Nov 15, 2005 | 08:46 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
It's not under the DUI section.
To Engine Drag Control
