I know many sight using a 17" for lower gear ratio but if you check the overall dimensions of the tire the difference is not significant.
A 275/35/18 and a 275/40/17 are very nearly the same diameter. And the 275/45/17 is actually taller than the 275/35/18.
Is it because you want to run ET's instead of BFG's?
MT makes a 17" DR, they don't make an 18. The BFG's are nice, but the MTs pretty much put them to shame. Probably would look awkward on a vette though.
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Originally Posted by shurite44
Why are you going with a 17"?
The benefit of the 17" is that you have more sidewall for flex and better grip. 17s will not clear rear Z51 rotors but I am pretty sure they will clear base brakes. I would use a 17x11 with 275/40 if possible and if you can get a little higher profile then use that.
Cajun
That makes sense, more sidewall, more flex.
I don't have the C6 but I am thinking about getting one. I still think if I am stock or fairly near stock I would just buy an extra set of front rims and run the BFG DR's.
