Headers in Calif.
Old Nov 18, 2005 | 01:46 AM
benspruce's Avatar
benspruce
Default Headers in Calif.
In December I am taking my vert to Andy at A&A in S. Calif to get a cam, tuning and Halltech air induction system. Headers were recommended but I understand they are "technically" illegal in Calif. Do any of you in Calif know if headers can screw up the smog test? I know some of you have headers, so why is there a potential problem. I am going to call Andy to discuss this, but I wondered what your input would be. Thanks.
Old Nov 18, 2005 | 01:58 AM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
I would worry about the cam and the tune, before the headers. (w/ cats) My experience has been that as long as it passes the sniff test, and there are no disconnected or missing smog parts under the hood, it will pass.
Old Nov 18, 2005 | 02:40 AM
RC51Driver's Avatar
RC51Driver
No headers are not illegal in California as long as they are C.A.R.B exempt and have an EO number assigned to that specific header. Go to the California Air Resource Boards' web site and they will have a list there of the approved headers that are legal. Any more questions let me know.
Old Nov 18, 2005 | 02:48 AM
RC51Driver's Avatar
RC51Driver
Just did a check and you didn't mention which headers you were looking at but a prime example are the B&B headers as they are C.A.R.B approved an carry an EO number of D-506-2
Old Nov 18, 2005 | 02:55 AM
4DCYKEY's Avatar
4DCYKEY
My experience is that normal gas station smog places will test the car for smog and it will pass the tests, and they will not know headers from normal exhaust. Caution should be noted, however, that the car can still pass the actual tests and fail the visual test of having headers, if an attendant is that astute. The whole visual test concept is beyond me...one should be worried about pollution, not a visual.
Old Nov 18, 2005 | 03:18 AM
shopdog's Avatar
shopdog
Ok, here's the deal. It is against federal law to remove, replace (with other than the exact OEM equivalent, and then only if you have proof the originals have failed), or relocate the cats. It is the last that gets you with headers, in particular, long tube headers. Even if you retain the OEM cats, they have to be relocated further from the engine. That can affect their cold light off characteristics, and the feds don't want that to happen. California follows federal law in this regard, so even if you pass the sniffer, which is done with the car already warmed up, you'd still be in violation if they spot the relocated cats during the visual inspection.
Old Nov 18, 2005 | 05:06 AM
midnite902's Avatar
midnite902
Default KOOKs
Kooks puts the cats in the stock location on the C6
One of the reasons I choose Kooks
Old Nov 18, 2005 | 11:05 AM
andreas g.'s Avatar
andreas g.
Default Halltech ???
I've got the cam, headers,cat backs,160 stat,and tunning. never had a code until I put a halltech on. Now I have a lean code for both banks at idle. My tunner said the Halltech sets this code on some motors. I put My moded stock unit back on and cleared the codes just to see what would happen. I'm going to see my tunner this week to see what can be done so I can use the Halltech. I had my cam done at A&A corvettes. The do great work for a fair price. Andy is great to work with. As for smog testing. Like the previous threads state; if you pass the sniffer you should be ok. But it wil never happen with a cam change. Anyway I hear there pushing the smog testing back to every 6 years instead of 4. That's a long time the contemplate what you want to do. Good luck with your choice.
Old Nov 18, 2005 | 11:21 AM
bunk22's Avatar
bunk22
I've been looking into long-tubes and this interests me. I currently have the Corsa Touring system, cat-back of course. What would be required, if anything, to swap to Kooks long-tubes? Meaning, would I need a new mid-pipe?
Old Nov 18, 2005 | 01:03 PM
andreas g.'s Avatar
andreas g.
Default bunk22
I have the kooks system, with magnaflows. The system includes the headers, 3 inch X-pipe and high flow cats,(one piece) and 3 inch mid pipes to the pipes starting your cat back mufflers. If you already have an x-pipe throw it away it won't work with the kooks system. The fit and finish is great. went in no problems,and never set a code. As for power after headers, moded stock air box, tunning and 160 stat I made 375RWHP/367RWTQ. most all of it from the kooks. Best bang for the buck. After the cam install making 420RWHP. Headers help the cam work up to it's full potential.
Andreas g.
Old Nov 18, 2005 | 02:16 PM
bunk22's Avatar
bunk22
Andreas g.
My mid-pipe is an H-pipe that came with the Corsa system. I've got the Halltech, 160 t-stat and the tune from Ron Zimmer. So basically, the system is about $1500, give or take, including everything? Any extra gas odor? How much louder than stock? I had a 95 Mustang GTS with long-tubes, no cats and it smelled and burned eyes like nothing else. It was loud as crap too. I would like to avoid all those things.
Old Nov 18, 2005 | 02:28 PM
TommyV's Avatar
TommyV
Umm, this is the stock C6 location:
Unless you get the Calloway or other shortys, the cats will be moved.
Old Nov 18, 2005 | 02:35 PM
TommyV's Avatar
TommyV
All the long tube headers relocate the cats and you need their catted mid pipes. The Corsa won't work.
Old Nov 18, 2005 | 05:04 PM
gray's Avatar
gray
I have the Corsa sport. What part of the Corsa would I actually keep? Just the mufflers?
Old Nov 18, 2005 | 09:19 PM
TommyV's Avatar
TommyV
The Corsa Sports will work, I'm talking about the x-pipe.
Old Nov 19, 2005 | 03:45 AM
shopdog's Avatar
shopdog
That's not the stock location, and those aren't OEM cats. Two strikes in the eyes of the EPA.
Old Nov 19, 2005 | 04:12 PM
rmitchell242's Avatar
rmitchell242
we have smog tests in ca
crap what have i done
i think it will pass still
To Headers in Calif.
Old Nov 19, 2005 | 04:38 PM
TomCat Vette's Avatar
TomCat Vette
I have a '95 Z28. Although I do have shorty headers my random tech y-pipe relocates the drivers side cat. I had it smogged twice this way never a prob with the visual. Because they never look. If they do and they tell you it doesn't pass a visual just go somewhere else. I had an intake on the Z28 that I made and went to one place and they told me they couldn't pass me because I had changed it and it doesn't carry a carb# (don't blame they didn't want to get busted). I just looked for a place that looked like they were into Hot Rods or fast cars and got it smogged no problem. Everything was hooked up the way it was supposed to be they didn't care they just said looks cool and asked me how much it cost me to make it then went about smogging the car.
Old Nov 19, 2005 | 06:07 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
Unless you get the Callaway or other shortys, the cats will be moved.
This is true - The "longtubes"all will be rejected at the inspection places, uness you have "made arrangements"
The C6 design actually sits closer to the head than the C5 design
Old Nov 20, 2005 | 04:57 AM
ShowcaseC6's Avatar
ShowcaseC6
St. Jude Donor '10
callaway makes shorty's for our c6.
you can use them with Random Tech. hi-flo cats. and then you can use your corsa xpipes.
