K&N Intake system
Old Nov 22, 2005 | 08:00 PM
69shrk's Avatar
69shrk
Default K&N Intake system
Has anyone used the k&n intake? any info??
Old Nov 22, 2005 | 08:15 PM
not08crmanymore's Avatar
not08crmanymore
Default k+n...
no,but I did sleep at a holiday inn last night! Go over to"other cars" section,there's a pretty informative writeup on that whole k+n thing.
Old Nov 22, 2005 | 08:24 PM
69shrk's Avatar
69shrk
thanks
Old Nov 22, 2005 | 08:54 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Old Nov 22, 2005 | 09:26 PM
Blue Demon's Avatar
Blue Demon
From: And then it was said... "let there be blue Corvettes and yellow Camaros" Ft Worth Texas
Cruise-In IV Veteran
St. Jude Donor '09
I just installed the twin K&N chrome/carbon fiber set up on my '06 Coupe, it looks great and the SOP results seem imopressive too.
Old Nov 22, 2005 | 09:49 PM
69shrk's Avatar
69shrk
Thanks Blue Demon for your reply Do you have any pics?? and hp gains??
Old Nov 23, 2005 | 01:22 AM
hodgeee's Avatar
hodgeee
According to K&N, it is 10hp peek at the tires, but if you look at the dyno sheet that they take, it gives about 10hp across the board from 2500rpm to 6200rpm. I noticed the most, was a much better throttle response, just quicker to rev up and downshift than before. Also at high speed passing, the car seems to pull much nicer.
Old Nov 23, 2005 | 04:31 PM
69shrk's Avatar
69shrk
thanks hodgeee had them on my C5 and was happy with them just wanted to see if they are the best fit for my C6
Old Nov 23, 2005 | 07:58 PM
TomZ's Avatar
TomZ
I dunno... I ordered the K&N FIPK for my 2001 C5 and was ready to put it in until I saw the instructions called for cutting and drilling (is this required for the C6)?
So.. I did more research and found that the SLP Blackwing (Lingenfelter) is a similar filter but requires no retro-fitting. Also.. there are greater hp gains with the Blackwing and (as I recall) is less expensive.
I always thought that I would go with a K&N, too, but I didn't want to buy a jigsaw to put it in (something just didn't "feel" right).
Good luck!
Old Nov 23, 2005 | 09:09 PM
zach lawrence's Avatar
zach lawrence
It's an easy install. No cutting, modifying necessary. Strictly a bolt-on. Takes 20 min - 1/2 hour.
Old Nov 24, 2005 | 05:39 AM
hodgeee's Avatar
hodgeee
Yeah the new one for the C6 does not require any cutting. On my last vette the filter element came apart though, so I unbolted it from the front, and just had it attached to the throttle body, hanging there, and that worked for over a year. This one, I did the same, just attached it to the throttle body and left the rest of the stuff off. Yeah, the cut in the last one allowed some air to come up into the filter, my friend cut his, and after I saw what little that would help, I just plainly installed my last one. But this one is a 10 minute bolt in.
Old Nov 24, 2005 | 03:33 PM
Blue Demon's Avatar
Blue Demon
St. Jude Donor '09
I haven't done a dyno on the new C6 yet so can't say about any HP gains but it sure does look great! Send me your email address and I'll send some pics.
Old Nov 24, 2005 | 11:47 PM
69shrk's Avatar
69shrk
I had bought mine for my C5 from RM racing with K&N filters and it was about a 25 min install no cutting they worked fine and i still have them but i havn't tried to put on my C6 i don't think they will fit.
To K&N Intake system
