Considering LPE 427 C6
and as for the resale you were speaking of ealier, maybe its because in ohio many people cannot afford a vette, here in atl they are not a premium and there are alot of buyers, check kelly blue book and see for yourself, we can drive our vettes all year round, and they are not cheaper in the winter so dealers dont have to deal especialy when the next buyer is right behind you waiting to buy..... as for the truth thing .. it sounds like your a little bitter.. sorry about that.
the point is that either way the lingenfelter is not just a name they did not make themselves known and get inducted into the corvette hall of fame for no reason.. they are known for there quality and there performance. and some of us work for a living THE CAPS WERE BECAUSE I WAS ON A PLANE TYPING FROM MY PHONE..sorry if reading in caps is difficult for you.. i hear hooked on phonics works really good ..
Well us pooo people here in Ohio are going get out of this one.
Thank everyone for their response. A few things I have learned:
1) LPE seems to be as reputable a tuner as there is, not cheap but well warrantied and hopefully reliable
2)Whatever you do or add in the way of modifications, there's forever the temptation to add a little bit more
3)Can probably never recapture your investment on mods in that they don't add commensurately to your resale value
4)Performance of C6 vert with LPE 427 should be roughly that of a Z06 although it would, conservatively cost more (approx $99,000 for the added engine alone w/o wider wheels) and may resale for less
5)Z06 enthusiasts will always opt for the Z06 package over a modified C6 regardless of their respective capabilities, and, by and large, are disinterested in owning a convertible version
6)There is some unexplained discordance in sale prices b/n Atlanta and Ohio
Actually, guys, this has all been very informative to me and I have learned a lot. Couple of other inquiries. I have noticed that a few other vendors (example MTI) advertise more HP that they can extract from a C5R than the LPE package -- is this from different cams/exhaust? And someone mentioned the coming availability of the LS7 block (i.e., C6-R), does anyone know if that would be available soon and if considering the 427 pkg would one be better off to wait on that?
Last question, is there some arbitrary HP number beyond which you shouldn't go without making more drastic mods to the car. In other words, to move beyond the 427 to the 427 TT pkg, would this dramatically compromise the life expectancy of the rear axle or even the C5R block? I guess it's a given that you'd require bigger clutch and bigger tires. Anybody have a guess at the approx difference in 0-60 MPH times or 1/4 mi times with these two packages?
Hey, thanks again for everyone's input, this really has been a learning experience for me and very informative. Also trying to decide b/n white, black, and yellow -- but I don't think anyone can help me there.
Cheers,
Jeff
Hey good luck, maybe you should check on a vert package on a Z06. Seems more cost effective to me.
There are ways to stiffen up the frame if you converted it to a vert. 5 point roll bar, and an abs of steel. And I bet the places that do the conversion have their own methods.
P.S. the C6R uses the block that is referred to as the C5R block. The LS7 block is the new Z06 block. You could just install a LS7 but there are issues. A C5R based motor is the way to go if you are doing 427 (I already looked into this)
I know you have a C6 but you can see what people think of the different SC for the C5, might help out. I heard SC can be quite noisy.
BTW, I have looked into the Z06 convertible conversion, spoke to Caravaggio and to a fellow at CUstom Coach CBuilder in Florida, both plan on doing it and opined that de-roofing wouldn't make a significant difference in torsional stability unless you were tracking the car. Nevertheless, I read enough posts about the aluminum frame being weaker that it scared me a bit and eventually led me down this path. We'll see how it goes...
2005 Callaway supernatural 490HP
The only supernatural C6 convertible on the planet. Special wheels auto trans, select ride control, 1700 miles, 78,880.
Contact number 610-827-7400, Tome Oates Chevy.
Disclaimer, I don't know this car or these guys, just passing on the add to you. There is a small pic, it is red.
-with the stock size wheels of the Z51 (or C6) there is simply not enough rubber to handle much more power...wonderful to talk about all these mega hp and torque numbers but got to get power to the ground. A BIG advantage of the Z06 over the C6 with a mod engine is the larger tires that the Z06 has...
-I like the driveability of the 366 set up... its power is very linear and not peaky>>>>
-I think the LPE 366 package is the most bang for the buck for a reliable company, heavily invested in R&D, impeccable reputation and back their work up. I do not like this piece mean aftermarket parts bin approach to gaining ++++ hp and torque. I think like LPE...it is a TOTAL engineered package to obtain reliable power not just a bolt on here or there approach.
-I have decided not to go with headers (the dyno chart above is based on LPE 366 package with BB X mid pipe and Corsa Sport exhaust)...too loud for my taste and I (my personal taste) simply don't need the additional torque...
-I like the idea of having the 366 still under the hood...and LPE shows how you can tweak that engine to new levels..
What I posted here is my opinion and tastes...each to his own and it is amazing what some are doing with their C6s....what makes this forum fun and informative
Michael
Lingerfelter 366 Package
Michael
I mulled over a supercharged Maggy 366 from LPE but decided on the 403.
My Dyno
Thanks John, Andy and everyone at 21st Century MuscleCar:thumbsup: :partyon:
:partyon: :thumbsup:
Thanks a ton for the insight. Very helpful info for me. I have only had the car a few months (4k). The idea of putting a new engine in it doesnt seem viable at this moment, although I like the sound of the "broader power curve" as opposed to the "build up" at 3000 rpm. What can I expect in terms of engine wear if I did a superchager? And what the differnce in cost?
Thanks again for the insite.
By way of example, I put 3.73 gears in my C5 b/c I didn't want to go into the engine and I just wanted a little more pep in my daily driver car. Then, the Magnuson supercharger became well-reputed for reliable fairly priced power and lots of history in OEM applications, so I figured what the heck.
Then, I get curious as to how it'll perform on the track so I make a few trips to the 1/4 mile experience. Then, my wife buys me an anniversary present cam!
Next thing, back to the track some more; oh, and better try roadcourse tracks, too. All along, buying lots of tires, some for street and some for the track. Then, adding an alcohol system to permit greater boost.
Then, I unexpectedly wrecked the car, so the cycle was stopped, at least for awhile.
So, if I were you, I'd read a lot in the C5 section and know that you have to filter out some of the rare experiences and seek the average for each type of approach and each vendor. And, most certainly, the more power you add, and the more frequently you drive the car hard, the greater the need to replace the very driveline items you mention and the less the chance to use the power on the street, even with the fattest available tires (unless you're going to drive around all the time with drag radials). There's no magic number, just general ranges, probabilities, and luck.
Best of luck -- you're off to a fun and great start.
I will tell you that some of the things that sound drastic, like swapping the motor in a new car are not as big a deal as they sound. If you think about it, half your drivetrain is going to come out if you change your clutch. If you swap the motor it's just the front half instead of the back half. You probably wouldn't hesitate to have a clutch swapped. You could sell the stock motor to recoup some of the money or you could save it and put the car back to 100% stock someday and sell the high hp motor. In fact every centrifigul S/C install is going to at least require cutting some shroud or something so it will (in some ways) be more intrusiv an install
If you want to go with a supercharger, I would definitely call Andy at A&A for his opinion. He is the forum sponsor for the C5 Forced Induction section. He has gotten alot more low end power with the vortec head unit than he was with the procharger. The only added maintenance with the procharger for me has been changing the oil in the head unit every 500-1000 miles. There is more to it than just bolting an S/C though. If you want it reliable, you have to upgrade the fuel system so don't just look at price, look at what you are getting.
However, everything i said is moot if you don't mind a raised hood. I'm personally not a big fan of them, but if that wasn't the case, and I had your goals, I would definitely bolt a Magnusson on. You could always sell it later if you want more. There is a new one about to be released (or just released) though so you might have to wait.
There is much more to the Z than just the Motor but I like my removable top and my car rides better than the Z for 90% of the driving I do.
Love the Z but I would not trade my car for one.
