ABS Is Always On
Old Dec 8, 2005 | 10:59 PM
Korzym's Avatar
Korzym
Default ABS Always Goes Off Regularly
Does anyone know how to get the ABS to shut off? It's real anoying not to mention dangerous. I don't want to take it in if this is a minor fix. Oh yeah, this isn't on a Vette but a Malibu. Don't freak out over that though, its Christmas time for crying out loud. Anyway I'd greatly appreciate any input from the resident tech pros
Old Dec 8, 2005 | 11:15 PM
lovecars's Avatar
lovecars
ABS is always on by default.
If it's going off when you are driving regularly there might be a problem with the system. That is not normal.
Old Dec 8, 2005 | 11:19 PM
Korzym's Avatar
Korzym
Yeah it regularly goes off, does anyone know if something could be tweaked to get it back to normal given that its hopefully a minor job?
Old Dec 8, 2005 | 11:24 PM
lovecars's Avatar
lovecars
Make sure tire pressure is correct, if you are a very aggressive driver the ABS will go on and the traction control will go on also.
Otherwise a trip to the dealer may be in your future.
Old Dec 9, 2005 | 05:43 AM
Korzym's Avatar
Korzym
Tire pressure is ok, no agressive drivers use the car. But I'm really hoping that you know somekind of mechanical trick
Old Dec 9, 2005 | 07:57 AM
Miaugi's Avatar
Miaugi
Take it to the dealer, or for something more radical.......pull the fuse!
Old Dec 9, 2005 | 08:10 AM
not08crmanymore's Avatar
not08crmanymore
Default abs
If you're saying the ABS light is on,then you need to see the dealer.That could be sensor issues,or aome other thing.Other than that,the abs does not become active till you slam on the brakes in a panic situation or the system detects the car sliding,in which case the traction also kicks in.They work together.
Old Dec 9, 2005 | 09:41 AM
robvuk's Avatar
robvuk
A properly functioning abs system is NOT dangerous but a safety feature! If it is NOT functioning properly, then it IS dangerous and it should be repaired by the dealer. This is not something to fool around with, as it could cause serious injury. It also works in conjunction with many other parts of the system and could affect a variety of other symptoms of drivability.
Old Dec 9, 2005 | 12:17 PM
Korzym's Avatar
Korzym
Thanks guys, too bad I won't be able to get my hands dirty!
To ABS Is Always On
