1st gear power delay...
Old Dec 17, 2005 | 03:08 PM
aliix's Avatar
aliix
Default 1st gear power delay...
when I release the clutch on my 6spd in 1st gear there is a slight hesitation in power then it kicks in.....is this normal or am I not using the clutch/gas correctly.....thanks
Old Dec 17, 2005 | 04:11 PM
nalto's Avatar
nalto
Don't know, what rpm are you at when the clutch begins to engage? If its too low(500rpm) it will momentarily bog down. I have found that 1000 rpm works fine.
Old Dec 17, 2005 | 04:57 PM
6 speed Sid's Avatar
6 speed Sid
You must not be coordinating the clutch release and the gas as there should not be a lag unless the clutch is slipping.
Old Dec 17, 2005 | 07:02 PM
Irv's Avatar
Irv
Normal. Torque management strikes again, in combination with your driving style. It's indicative of so-called "granny shifting" (pausing ever so slightly when coming out of one gear and engaging the next) followed by a large throttle opening.
Old Dec 18, 2005 | 02:35 PM
Bumpstick's Avatar
Bumpstick
Launch Controll ?
Old Dec 19, 2005 | 10:57 AM
calemasters's Avatar
calemasters
I agree. I also, sometimes, get it in 2nd and 3rd.
Old Dec 19, 2005 | 11:18 AM
AK's Z's Avatar
AK's Z
It is "Launch Control", which keeps the HP down to about 290 HP instead of the listed 400 HP, regardless of how much rpm you give it, 2nd and 3rd gears are a little better. You need to have the LS2 Edit done to get rid of the Launch Control and Torque Management lag/bog.
Old Dec 21, 2005 | 04:41 PM
JmpnJckFlsh's Avatar
JmpnJckFlsh
Some vehicles (trucks, SUVs) with manual transmissions have an throttle linkage dampener to let the engine down to idle speed slowly during shifts to keep you from engaging the clutch on an idling engine. Newsflash: Corvettes DO NOT have such a dampener (or throttle linkage either)...Conclusion: Corvettes with manual transmissions are meant to be shifted expeditiously, not slowly and deliberately like your grandmother's 40-year-old Falcon.
You will have to learn to shift quickly, and ease in a little throttle before/as you re-engage the clutch...it takes a few days, but you'll get the hang of it. And, be careful about how much throttle you ease in...you'll be wondering how you ever thought it was "hesitating".
Old Dec 21, 2005 | 08:43 PM
SpinMonster's Avatar
SpinMonster
Tuning got rid of it for me. The car in stock form had a hesitation when you hit the gas. Its an LS2 thing even on the GTO.
Old Dec 22, 2005 | 08:47 PM
spectra6.0's Avatar
spectra6.0
Are there any hand held programmers like Superchips or Hypertech on the market for the C6? The car is bone stock except for CAGS and K&N filters so I don't think I need a custom tune.
Old Dec 24, 2005 | 12:34 AM
Brannon's Avatar
Brannon
I checked today to see if the LS2 edit gets rid of it yet. Not yet, I was told maybe in a few more months.
Old Dec 24, 2005 | 08:27 AM
davidfarmer's Avatar
davidfarmer
LS2edit does it for 05's. You can adjust torque management, and remove launch control, traction control, AND wheel Hop management.
Old Dec 24, 2005 | 12:19 PM
Brannon's Avatar
Brannon
I called 21st Century Muscle Cars and they said you could adjust timing pulled, but the LS2 edit would not completely get rid of it yet. I had the LS2 edit when I got my headers and cam and I believe it was adjusted like your chart shows, but my car still does not pull in 2nd and begining of 3rd like it should. Maybe its my imagination.
Old Dec 25, 2005 | 04:05 PM
Tom Beames's Avatar
Tom Beames
This is so frustrating!! My new 2006 (11/25/2006), Monterey red, Z51 is impossible to shift smoothly from 0 to 1st, 1st to 2nd and 2nd to 3rd. After that it is okay. I know nothing about cars but I think it is loosing RPM's too quickly. Even people who want to "try it" say the shifting is terrible.
I also experience "loping" when in 1st or 2nd while driving at "neighborhod" speeds-gain and lose, gain and lose.
Finally, when I back out of my driveway, I better set the wheels straight before going forward or else the front end "jumps"-much like a 4 wheel drive vehicle does when in 4 wheel drive and turning too sharply.
Please help!!!!! This is very frustrating. I'm ready to go back to my C5!!
Tom Beames
tbeames@weichertrealtors.net
To 1st gear power delay...
