Optima batteries?
Old Dec 31, 2005 | 02:01 PM
BlackC6's Avatar
BlackC6
Default Optima batteries?
According to their website, they only make batteries for corvettes up to 2004.
Are there models that will work with the C6?
Old Dec 31, 2005 | 02:46 PM
Waveblaster785's Avatar
Waveblaster785
Last I checked a 12v battery was a 12v battery. You may just need a new bracket to hold it in place.
www.eddiemarine.com has some nice optima brackets, that's what I used on my Lightning.
Old Dec 31, 2005 | 03:02 PM
BlackC6's Avatar
BlackC6
Thanks, I will checck it out.
Old Dec 31, 2005 | 03:23 PM
VET4LES's Avatar
VET4LES
True 12 volts is 12 volts but they come in all shapes and sizes. Which ones will fit in the C6 is the question. Boat brackets look great and hot rod shops have good looking ones also.
Old Dec 31, 2005 | 03:41 PM
wwashing's Avatar
wwashing
C6s take the same size battery as a C5.
You want Optima Red Top model 34/78, part number 8004-003.
Old Dec 31, 2005 | 04:17 PM
BELVIN20's Avatar
BELVIN20
Exide Orbital ORB-78DT-84 works as well, and no additional brackets needed. Can be found at Walmart and other retailers as well as local parts stores. You can go to www.exide.com and find a supplier close to you.
Old Dec 31, 2005 | 06:03 PM
Buy-Low's Avatar
Buy-Low
Default Optima Yellow Top
Optima recommends the Yellow Top. I had one in my 98 C5.
Old Dec 31, 2005 | 06:14 PM
Rick Kasick's Avatar
Rick Kasick
Cruising
Default C6 Battery
Why are we buying batteries? GM just put a new battery in my C6. 1800 miles and it was is storage with the negative cable off thinking it would solve the problem of not starting after one week. Same result. Had one good day of weather (NW Indiana) and got it to the dealer. Technician said to keep a "battery tender" on it or take the battery out. I also looked at the Optima battery but figured GM should handle it for $50,000.
Am I wrong?
Old Dec 31, 2005 | 06:47 PM
TexasTechZ06's Avatar
TexasTechZ06
I have had a red top on my '05 for a year...no more DBS!
Old Dec 31, 2005 | 06:50 PM
Waveblaster785
Why spend extra money and get a red top? If you are spending for an optima, get a yellowtop.
Old Dec 31, 2005 | 07:01 PM
VET4LES's Avatar
VET4LES
Am I wrong?
Your right.
Old Dec 31, 2005 | 09:44 PM
Rick Kasick
Cruising
Default C6 Battery
Thank you!
Happy New Year
Old Dec 31, 2005 | 11:51 PM
BlackC6's Avatar
BlackC6
Thanks guys, this is the info I was hoping for.
Is the official recommendation then a yellow top and a battery tender?
Old Jan 1, 2006 | 02:45 AM
sdowney's Avatar
sdowney
well the truth is it depends on what you want. the yewllow top batteries are made to be drained and charged over and over in extreme car audio situations. if you just have a stock stereo then a red top gives you all of the optima battery positive attributes. as far as i know there is only one size optima battery.
Old Jan 1, 2006 | 03:27 AM
Steve Germany's Avatar
Steve Germany
Yes, you are correct for min hassle. A couple of cases of DBS will confirm this. A priority start module with the GM replacement battery is the route that I ended up going.
Old Jan 1, 2006 | 07:30 AM
timd38's Avatar
timd38
You can put the group 35 in a 05 because it came with a group 86 battery and they should interchange. The 06 comes with a T5 and so the cables are reversed and the cable ends are funky becasue of the DIN cover. I have a group 34 in my garage, and am going to fit next week when I get my replacement car that is at the dealer waiting for GM legal to release it.
Optima is working on a new catalog.
Old Jan 1, 2006 | 12:41 PM
Waveblaster785
I plan on a yellowtop to help out my stereo when I install it.
To Optima batteries?
Old Jan 1, 2006 | 01:40 PM
timd38's Avatar
timd38
With a high powered stereo, you would want a Yellow top, because it will take cycling better than a red. The Yellow has more paste on the plates that is also of higher density than the Red. You do sacrifice CCA by using the Yellow, but most cars don't as much CCA as they used to.
Old Jan 1, 2006 | 01:43 PM
timd38's Avatar
timd38
Am I wrong?
Putting an Optima in isn't going to fix the problem, it is just going to take cycling better. Please keep in mind that the battery that comes in a car is an SLI (starting, lighting and ignition) it is not designed to be charged and deeply discharged and that is what DBS does, so it eventually kills the OE battery.
Old Jan 1, 2006 | 01:44 PM
timd38's Avatar
timd38
Better buy a lotto ticket, your just lucky.
