Procharged C6
Old Jan 1, 2006 | 07:06 PM
Rare ZO7's Avatar
Rare ZO7
Default Procharged C6
How is it possible to run 6-8lbs. boost on a 10.9 to 1 comp. C6? I live in N. California, with less than 93 octane.
Old Jan 2, 2006 | 07:43 AM
aquikv6's Avatar
aquikv6
Cruising
Detonation could be a problem depending on the tune. You might want to consider one of the methanol/alcohol injection kits. Hight boost is possible on the street with pump gas and you don't even know the kit is there.
Old Jan 2, 2006 | 10:41 AM
Romeo90626's Avatar
Romeo90626
Default 91 octane required
]How is it possible to run 6-8lbs. boost on a 10.9 to 1 comp. C6? I live in N. California, with less than 93 octane.[/QUOTE]
Those of us in FL have access to 93 octane pump gas.lol I did not realize until I went to Denver recently that they still make 85 octane fuel and that they max out at 91; 2005 Vettes run fine on 93 octane with 6 lbs. boost using the intercooled Procharger; mine does. Procharger only requires 91 octane, so you should be fine also. There should be no need for any additives. Ed Wright does the computer tuning for Procharger. INSTALL THE Procharger kit and hold on!lol
Old Jan 2, 2006 | 11:22 AM
Mr.Big's Avatar
Mr.Big
I do run 93 octane in mine in Texas, with a VERY conservative tune at 5.5psi she makes 620rwhp. I would call Andy at http://www.aandacorvette.com/ he has built many F.I. cars for Cali guys. One of the guys that has an ATI kit on this forum is Brabus2, Andy's guys did the install on his, and he is VERY satisfied. Brabus2 is in in the SFV area, check out his posts...
Go for IT!!!
Jeremy
Old Jan 2, 2006 | 11:52 PM
vertC6's Avatar
vertC6
I would not risk it, just throw in some torco and that will bump it up to 95 to 96 octane.
Old Jan 4, 2006 | 07:11 PM
burkolator's Avatar
burkolator
Default Where in Florida
I live in Miami and am thinking of adding the ProCharger. Can anyone recommend a good mechanic and also the estimated cost. Thanks!
Old Jan 9, 2006 | 10:52 PM
Crazy Cowboy's Avatar
Crazy Cowboy
Premium Supporting Vendor
From: www.EXOTICVETTE.com - FL Cruise-In VI, VII, & VIII
Cruise-In V Veteran
St. Jude's Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Anyone tell me what you've run with the ATI in the 1/4 mile on a stock C6 coupe or with a cam too?
Old Jan 9, 2006 | 11:42 PM
haljensen's Avatar
haljensen
Retard the timing and run super rich @ WOT.
Old Jan 10, 2006 | 12:28 PM
Snake Slayer's Avatar
Snake Slayer
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
I would reccomend Mike Norris of Next Level Performance. Mike is just outside of Orlando. NLP is also a forum sponsor.
Old Jan 10, 2006 | 01:26 PM
SpinMonster's Avatar
SpinMonster
For a stock car the kit comes with tuning done already.
Old Jan 10, 2006 | 01:33 PM
Atomic-Vette's Avatar
Atomic-Vette
a lot of that has to do with the altitude. they are so high they don't need the higher octane gas. Living in a low area is kind of like a natural supercharger.
Old Jan 11, 2006 | 08:42 PM
glass slipper's Avatar
glass slipper
It's actually very easy with a centrifugal supercharger. Let's say it makes 6 PSI boost at 6000 RPM, that translates to about .75 psi @ 2000 RPM, 1.5 PSI @ 3000 RPM, and 3 PSI @ 4500 RPM (remember boost varies with the square of the RPM factor...double the RPM means 4 times (2*2) the boost, triple the RPM means 9 times (3*3) the boost). Knock/detonation is mostly a low RPM phenomenon, meaning it's more likely to happen at low RPM. At higher RPM, there is more turbulence, better mixing, and less ignition delay (means the chemical reaction occurs quicker allowing less time for another knock producing flame front to begin). With intercooling and methenol/alcohol injection, you can run big boost (8-10 PSI, maybe more) on a stock engine and make some big HP numbers at high RPM with no worries about knock/detonation because 10 PSI @ 6000 RPM is still only 2.5 PSI @ 3000 RPM. Just don't expect equally big gains at the lower RPMs, in fact, it'll be close to stock since you're not making much boost. Proving once again you don't get something for nothing.
To Procharged C6
