Dyno result with the A6
Old Jan 3, 2006 | 03:12 PM
TMyers's Avatar
TMyers
Default Dyno result with the A6
Just finished geting baseline for my car, totally stock. 337hp at 6000, 341ft lbs of torque and 4500. 3 runs where done, the first in 3rd the next 2 in 4th. The 3rd run was the best. Looking at the A/F chart the car runs fat from 4000 rpms to redline, 11.7 at 6000. Anyway thought I would share.
Old Jan 3, 2006 | 03:17 PM
LS1LT1's Avatar
LS1LT1
Thank you for the info/results, I was curious what it be with the new trans, seems right in line with the A4 cars.
Tough call as to which gear to dyno in with the lack of a true 1:1 ratio gear.
Old Jan 3, 2006 | 03:41 PM
TMyers's Avatar
TMyers
Oh the other cool thing 4th tops out at 165 or so. From 2300 rpms to 6500 took 16.4 secs.
Old Jan 3, 2006 | 04:01 PM
Anonymous 1's Avatar
Anonymous 1
165 MPH? Sounds like you may want to use third gear.
Which one is closer to 1:1 ?
Old Jan 3, 2006 | 04:12 PM
TMyers's Avatar
TMyers
I think 4th is 1.09:1.
Old Jan 3, 2006 | 04:32 PM
VetVetter's Avatar
VetVetter
From: YOU SEE ... I'M NOT CRAZY ...I'M JUST AHEAD OF THE CURVE
St. Jude Donor '09-'10
Very nice
Old Jan 4, 2006 | 02:37 AM
SoldSyclone's Avatar
SoldSyclone
3rd 1.53
4th 1.15
Old Jan 4, 2006 | 12:24 PM
atoyf's Avatar
atoyf
that's very low...
especially considering the rear axle gearing - 2.x something... the car must feel "doggish"
Old Jan 4, 2006 | 12:57 PM
TMyers's Avatar
TMyers
Originally Posted by atoyf
that's very low...
Low as in HP? I thought it was very good actually considering we are talk an automatic here. I was expecting a 20% loss because of it. Am very happy with 15-16%. That is not bad for total drive line loss IMO. I have seen manuals with that type of loss.
Concerning feeling doggy, nope. Gearing falls between the standard MN6 and the Z51 MN6.
Old Jan 4, 2006 | 01:16 PM
LS1LT1's Avatar
LS1LT1
that's very low...
Low hp or low speed (165)?....I don't think he meant the car's top speed is 165, only the top speed in 4th. The car should go 172-175+ I'd bet.
As for rwhp, almost ALL automatics have dyno'd in the 330-345 range, some as low as 320 even, 337 seems quite normal to me.
Old Jan 4, 2006 | 02:15 PM
atoyf's Avatar
atoyf
sorry fellas for the confusion and not being clear...
im just brain storming out loud... coming from Z06 that dynoed almost 370 with just air filter...
and 2.86 rear axle gears is just way small for this car (2006 A6 that's what's coming towards my way)...
Old Jan 4, 2006 | 03:54 PM
TMyers's Avatar
TMyers
It's 2.56 actually. The following was put together by SoldSyclone with some mods by me.
A6 effective - 2.56 rear
4.02 10.29
2.36 6.04
1.53 3.92
1.15 2.94
0.85 2.18
0.67 1.72
Z51 effective - 3.42 rear
2.97 10.16
2.07 7.08
1.43 4.89
1.00 3.42
0.71 2.43
0.50 1.71
M6 effective - 3.42 rear
2.66 9.10
1.78 6.09
1.30 4.45
1.00 3.42
0.74 2.53
0.57 1.95
Old Jan 4, 2006 | 04:25 PM
atoyf's Avatar
atoyf
4.02 10.29
2.36 6.04
1.53 3.92
1.15 2.94
0.85 2.18
0.67 1.72
2.97 10.16
2.07 7.08
1.43 4.89
1.00 3.42
0.71 2.43
0.50 1.71
2.66 9.10
1.78 6.09
1.30 4.45
1.00 3.42
0.74 2.53
0.57 1.95
see, from a roll, same HP cars, but with different gearing would walk A6 with stock gears! 1st gear looks good, but the rest not very, 3rd and 4th ratios should be bigger on A6....
Old Jan 4, 2006 | 04:37 PM
TMyers's Avatar
TMyers
Gearing is just part of the story. Even if they are geared the same the manuals will probably walk the A6 because the auto is giving up HP, probably about 20HP.
But you are not going to change that much with a rear gear change. Change it enough to get a good 3rd and 4th is going to kill first. Anyway we will see what times I can put down when the track opens up in March.
Old Jan 4, 2006 | 06:48 PM
Waveblaster785's Avatar
Waveblaster785
What kind of speeds are you going from a roll that youa re starting in 3rd?
My car with the A6, was door to door or pulling on a C5 wiht a converter, exhaust, intake and TB.
I wanna line up with a M6 and A4 guy in the MD area. I bet it's all driver, in fact I bet me in an auto takes the average manual driver every time. My car is bone stock, bring your bone stock car and lets do this.
Old Jan 4, 2006 | 06:54 PM
atoyf's Avatar
atoyf
most races are good to start in 2nd and end at the end of 4th
but i might be thinking like a "stick" guy...
Old Jan 4, 2006 | 07:55 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
To Dyno result with the A6
Old Jan 4, 2006 | 09:19 PM
TMyers's Avatar
TMyers
Where does this come from. So many things go into what gear you want to start in. 3rd gear in the A6 is good for around 135. So start in first and end in 3rd. Look at most of the trap speeds people are getting in the qtr, between 105-120. Guys with the Z51 are having to shift into 4th at around 110 because they hit the rev limiter at 113.
I would think the best bang for the buck with the A6 would be a different stall converter and and tires. After that adding more hp. I don't know what 135 trap speed would be in ET but my guess is you would be knocking on the 10's and only need 2 gears shifts to get there.
Old Jan 7, 2006 | 02:38 AM
SoldSyclone
mine seems to top out around 127-128 in 3rd but things happen fast up there
Old Jan 7, 2006 | 03:21 AM
shopdog's Avatar
shopdog
3 speeds in an automatic are all you need to get the job done, the rest is just dead weight, at least until you want to cruise.
