LG Header install/pics/dyno
Old Jan 4, 2006 | 04:38 PM
VetVetter's Avatar
VetVetter
From: YOU SEE ... I'M NOT CRAZY ...I'M JUST AHEAD OF THE CURVE
St. Jude Donor '09-'10
Default LG Header install/pics/dyno
My bad for getting this information in 3 other seperate threads ... thought this might help those searching in the future for a consolidated view and info sharing.
C6/MN6
only modification before LG header install was B&B Bullets I put on.
Dyno Results (Mustang Dyno at Curry's in Sterling, VA ... awesome shop and service btw for fellow Northern Virginians):
Before: 353 HP (5750 rpm) / 355 Tq (4500 rpm)
After: 365 HP (5750 rpm) / 376 Tq (4250 rpm)
I had the LG Pro long tubes with high flow cats (JetHot coated as well). The installer drilled a hole in the steel tunnel plate to better thread and protect the O2 sensors since they relocate back further.
Dyno test:
http://www.pnwzr1.net/Blue_Demon_Dyno_Test.MOV
-or -
http://www.clipshack.com/Clip.aspx?key=9243EFF0DC38DEAF
Old Jan 4, 2006 | 06:07 PM
GentleBen's Avatar
GentleBen
Cruise-In 7-8-9-10-11-12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I agree that Curry's is an outstanding operation. They also installed my uncoated LG Headers and Hi-flo cats and Corsa Sports on my C6. Interestingly, I ran lower numbers than VetVetter's (350.9 RWHP / 349.0 RWTQ) on their dyno.
Not to start any arguments over the relative merits of Mustang and DynoJet systems because there are variables such as altitude, temperature, humidity, exhaust system, etc. involved but the before runs on the above configuration on the Lingenfelter DynoJet showed 376.2 RWHP / 375.6 RWTQ before the 403 cid engine upgrade. Afterwards the LPE dyno indicates 470.2 RWHP / 468.2 RWTQ and I am very happy with all the mods to date.
Old Jan 4, 2006 | 07:23 PM
RyanC7's Avatar
RyanC7
Im in Ashburn where is this place?
How much for install??
Old Jan 4, 2006 | 09:55 PM
VetVetter's Avatar
VetVetter
This shop is in Sterling just a few exits past Dulles (coming from Rt 66) - easy to get to and not to far off rt 29.
~800$ for install/shop parts and they prob work some deal for the 2 dyno's ... not discounted I think they are 105$ a piece.
They have done enough C6's now that it's a good insurance policy
Old Jan 4, 2006 | 10:00 PM
VetVetter's Avatar
VetVetter
Holy crap - nice numbers ... that's where I want to be eventually. Have you done anything to the rear end or drive shaft? If not, I would assume it is handling it ... I guess the conventional wisdom is that up to 500 hp/tq the stock can handle as long as you aren't using drag slicks and racing every weekend.
I guess my next step is to get the car out to Lingenfelter
Old Jan 5, 2006 | 01:17 AM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
They look Sweeeet
Old Jan 5, 2006 | 07:45 PM
SINCITYC6's Avatar
SINCITYC6
How big does the hole in the tunnel plate need to be?? What would be required to cut it?? Did the installer have to remove the plate or can it be cut on the car?? TIA
Old Jan 5, 2006 | 07:50 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
I would like to know too !
Is this only for the Aftermarket Tunnell Plate
Or do you have to drill a hole in the stock one too !
Old Jan 5, 2006 | 11:15 PM
Nickedimus's Avatar
Nickedimus
its can be done on the car but easier off the car. ,if you have the exhaust apart you might as well take the tunnel plate off as you'll have a bunch of metal shaving when your done. the hole size is i believe 2". i used a holesaw on a cordless drill. the factory plate is paper thin, itll go thru it like a hot knife thru butter. aftermarket plates such as elite's work too, just take a lil more effort (elbow grease). oh yea and yes you should do it for extra clearance, but most importantly for safe routing of the rear 02 sensor wire extensions.
hope this helps.
Old Jan 7, 2006 | 04:31 AM
Jagcvette's Avatar
Jagcvette
[QUOTE=GentleBen]I agree that Curry's is an outstanding operation. They also installed my uncoated LG Headers and Hi-flo cats and Corsa Sports on my C6. Interestingly, I ran lower numbers than VetVetter's (350.9 RWHP / 349.0 RWTQ) on their dyno.
GentleBen, I'm in Springfield and will be getting my 06 back from LPE next week. I am also interested in getting the headers and highflow cats installed. Your numbers are great. Can you tell me where you ended up getting your headers from how long they need for the install: can they do it in one day or do you need to drop it off? Thanks, Jeff
Old Jan 7, 2006 | 06:55 AM
C6RAPTOR's Avatar
C6RAPTOR
hope this helps.
Does anyone have PICS of the hole in the tunnel plate? I have the thick aluminum plate with my new LGs ready to install.
Old Jan 7, 2006 | 07:49 AM
SC TROJAN GRAD's Avatar
SC TROJAN GRAD
nice write up.
Old Jan 7, 2006 | 08:29 PM
PaBlueCoupe's Avatar
PaBlueCoupe
St. Jude Donor '06-'07-'09
ing on this one. Just a matter of time.
Thanks for the post!
Old Jan 8, 2006 | 12:49 AM
VetVetter's Avatar
VetVetter
I should have taken a pic of it - sorry.
The hole he drilled with a simple drill - it look maybe like 1/2". I only have the stock plate in ... he just drilled it in place right above where )2 sensor is in the pipe so it goes straight up and away from the headers.
To LG Header install/pics/dyno
