Ok a lot of guys were saying that you would probably loose power with this setup, I finally dynoed the vehicle with it on.
Before my car made 353hp and 356tq at the wheels with just a K&N intake.
After Flowmaster car made 358hp and 374tq. That is about 5hp and 18ftlbs.
Yeah the shop owner and tuner said that he was surprized that I did not loose any power as some guys have. He was impressed with the torque though. He also stated that most guys who get the Corsa's or Borlas get about 10 to 12hp at the tires and about even tq.
I knew that the vehicle seemed to pull a little harder down low, but up top I could not feel any difference. The shop owner recommended before I do long tubes that I get one of those exhaust systems he recommended cause he said that the vehicle will be crazy loud and may not give me full potential with the Flowmasters.
Wow, that seems like an awfully large gain in tq, that's like almost the average gain from long tubes. I wonder how your A/F is and if this leaned it out too much or something.
Thats great...almost 20 pnds of torque. Not bad for a system thats atleast 1/2 the price of other catbacks. Flowmaster has a great reputation and you just proved it for us......and you cant beat the flowmaster muscle car rumble.
thanks for posting
It does seem to be not the norm with those gains. My catback netted me nothing at the track and from the SOTP, nothing was there. Can you post the dyno sheet?
That is with ls2 edit tune on the vehicle, and dynoed to run at 13 to 1 air fuel ratio. He said that the tune was really running rich on the stock tune.
With just the dyno baseline, the car picked up the same 5hp and 0ft lb of torque(that could just be a variable between runs.) The tuner, Gill Naverez(you might have seen him on "Rides") says he tunes for acceleration, not hp or good dyno sheets. Gil did say that he was impressed with the torque, and that my numbers were not the norm. He showed me other dyno runs with before and after catbacks, and the Corsa's and the Borla's did show the same kind of numbers, approximately 10 to 12 hp and torque at the tires. He said that my motor is a little bit of a freak, cause all the other cars he has run on the dyno from the vette club averaged from 333 to 337 with just an intake, and that 353 was pretty damn good. I have raced a guy at work with his 2003 Z06, and I usually take him by about a car and a half by 100mph.
I have the dyno sheets but no way of posting it. Sorry, I need to buy a scanner or something, or maybe buy a digital camera.
To the other post that said he saw no gains before from flowmasters, are any of those results from the NEW C6 flowmaster system? When I talked to flowmaster they said they designed the c6 system from the ground up so if it's not this specific system than it's not valid info. Atleast this thread is concerning the new c6 flowmaster system and the results are positive even if it is with a tune. Bottom line is that bang for the buck in terms of exhausts you just cant beat the flowmaster catback which can be had for under $400.
Forgot to mention in my last post that I doubt all the gains were from the tune because if you read the original post even the shop owner and tuner was surprised by the gains, if he thought the tune was the complete reason I doubt he would have mentioned it since that what a tuner does everyday. To me it appears that the tuner was impressed by the combo of the flowmaster catback and the tune.
An exhaust that is built for low-mid range power and torque gains would show numbers like that but I'd like to see the graph and see whats happening at 1-2-3-4,000 rpm relative to baseline. If you build for power there you cant have it on top too, there is no free lunch.
I understand the relationship between HP, TQ, RPM and the effect of airflow and valve timing on the above. I know there is no free lunch when it comes to designing an engine and where peak HP and TQ occur with respect to engine speed.
This is not the same thing as reducing the diameter of primary tubes on a set of headers to increase velocity and low end torque at the expense of top end performance. This is a cat back exhaust system.
If you were talking camshafts, I would agree with you. However, I find it hard to beleive that an aftermarket exhaust system would be designed to reduce the engine speed at which peak HP occurs.
It's uncommon because big HP numbers sell pipes. Most people and most driving styles would be happier with more hp in the low and mid range where you do MOST of your driving.
The problem lies in the advertising. If you cant say it has X more peak power it doesnt sell because people buy those numbers.
Me personaly, I'd preffer 10hp from 1500 to 4500 and I dont care if the peak showed any gain. Thats where MY tach spends most its time.
You won't get any argument from me on a preference for gains in "area under the curve" vs peak HP and TQ. All I am saying is that those dyno numbers don't add up.
I was answering your previous post and by the term 'under the curve' do you mean under peak?
