spring clutch
Old Jan 8, 2006 | 06:32 PM
c6lover's Avatar
c6lover
Default spring clutch
would any1 know if its possible to take that spring out of the clutch because its very bothersome i like to feather out the clutch how i like and not have it shoot back at me.. would an after market shifter kit resolve the issue of having a stiff shifter. i hate having to be a bodybuilder to shift... if any1s remove that spring a little how to guide would be helpful thank you
Old Jan 8, 2006 | 08:29 PM
cbrf4i1's Avatar
cbrf4i1
most people says with the clutch spring removed there is less a effort required for the leg, i personally couldn't tell a difference..the spring is actually there to help you push down the clutch.....so if you are looking to not "shoot back at you" the spring will not help you with that..just try to pop the spring out at the 2 holes on the sides NOT THE WHITE U CLIPS...It will only take you a few seconds....
Old Jan 8, 2006 | 08:54 PM
radstoy's Avatar
radstoy
Wow my clurtch is way too easy to push to the point where there is no sense of when the clutch is starting to grab. I was under the impression that removing the spring would make the pedal a little more firm.
Old Jan 8, 2006 | 09:06 PM
Mayonayze's Avatar
Mayonayze
From: Prepare yourself, for a pride obliterating bich smack. Fairfax, VA
St. Jude Donor '06-'07-'08
SEC > BCS 4 St. Judes '09
Old Jan 8, 2006 | 10:15 PM
cbrf4i1's Avatar
cbrf4i1
i am sorry, just reread my post and realized i missed tpyed.....most are reporting there is MORE EFFORT required after the spring is removed.....i couldn't tell
Old Jan 8, 2006 | 11:56 PM
AK's Z's Avatar
AK's Z
Took my spring off with a flat head screwdriver, less effort to press the clutch in and the feel is ALOT better.
Old Jan 9, 2006 | 04:40 AM
c6lover's Avatar
c6lover
i figured less effort theres no spring to fighting against you... ill try to carefully pop it out... thx
Old Jan 9, 2006 | 12:29 PM
BlackMagik's Avatar
BlackMagik
What about the problem people have reported at high RPMs of the clutch peddle sticking to the floor? Will this aggravate it?
To spring clutch
