Aluminum Flywheels
I notice no clutch engagement issues at all and always thought after installing it that people like to spread the same false rumors around that seem to exist when people comment on things they never tried personally.
I was told by cartek personnel that they have seen these flywheels warp under severe conditions. I state that as a possible issue for drag racers who also argue that a bog may exist with some set-ups. For my street-only vette, its a winner all around. The car once in gear is so much faster that it is hard to imaging anyone having one of these for street use could argue for a better mod especially if the car is in need of a better clutch due to wear or power mods.
The test I spoke of:
http://www.vetteweb.com/tech/0407vet_flywheel/
Jeremy
In the first graph the TQ curve of the modified vehicle is higher than the unmodified vehicle from the low end towards the upper midrange. Then the TQ curve of the modified vehicle dips below the unmodified vehicle, and yet the HP curves do not dip below.
Since HP = TQ * RPM / 5252
Any time the TQ curves have the same value at the same RPM the HP numbers have to be identical.
This smacks of dyno graph manpulation.
However, I am fully on board that light weight flywheels do good things to performance.
[/QUOTE]It appears that you started the run at 2500 (base) and 2700 (tuned) and it isn't valid to put your 11sec time into the mix. I know you're not a fan of alum fly's on the track but for a street car its a great mod. Obviously mt point is that it isnt a measurment to use to compare car to car but rather same car, same dyno, same day/weather. How long it took your car on a different dyno, different day doesn't say anything about what a lighter set-up will do for your street car. I wonder what you would use if you kept this car long enough to warrant/need a clutch. Bogs on the track don't hold water on a street car unless you test your zero to sixty on the street as the standard rather than in gear passing power.
I was at ECS in NJ while Chris was tuning his car...seemed to be 5-6 seconds but then he has an auto and 700rwhp.
As pointed out the dyno graphs show how many seconds it took to make peak power not RPM vs. power. I thought people would recognize (and appreciate) that a simple mod that doesnt cost much if you are in need of a clutch gains simply by reducing parasitic loss.
I have a spec 3/fidanza on my C5 and RAM sd 900/fidanza waiting to go in the C6.
I have a spec 3/fidanza on my C5 and RAM sd 900/fidanza waiting to go in the C6.[/QUOTE]
It's been many years since I was really active in racing but when we went from Al to steel flywheels we picked up a bunch on time. Why you ask, well that with the current C5 or C6 traction is a big problem and the 1st gear delta rpm is the greatest but short lived. The energy storage is mainly done in 1st gear when your more concerned with hooking up anyway so who cares how you spin up. The energy now stored in the heavy flywheel comes into play at the shift points and is transferred at that point, that’s a good thing with narrow delta in rpm’s for the remaining 3 gears. The al was great in circle track when in just one gear and accelerating out of corners down back and front stretches. With road courses you keep your rev’s up in a narrow range with the transmission along with the stored energy in the rotating flywheel. Where am I going wrong here? The car I ran when active was a 55 chev with a 327 and we launched at 7000rpms and no bog with the steel wheel.
You keep using race performance as the standard and for those not interested in aggressive clutch shifts and hard launches and just looking for passing power this mod has no downside.
In my corvette, the aluminum flywheels made it faster. Phil97svt (this forum) runs one of these with 1.4x 60 foot times so until you show a CORVETTE that was actually slower from using one stop offering that as fact. I have had this coversation with you before and said my 68 dart runs one with no bog so why is that not countering your experience at all?
IE...run 3 1/4 mile runs and then swap the flywheel to see if there is an improvement. That still wouldn't reflect my street driving but it seems to be the universal language for some.
If the test involved a 4th gear run-up on the hiway to redline...150mph it wouldnt solve anything either....and.. does the bog negate the faster in-gear pull?
I beleive it wouldnt change your mind either way. Even if the car ran 3 11.75's then a 11.63 you would attribute it to something else because you felt a bog in a 55 chevy. BTW, nice car. I still have my Dart but I don't recall you saying if you still have the 55 do you?
You could take the mass polar moment of intertia of the two set ups, a stock acceleration run and calculate the apparant increase in horsepower and torque far more meaningfuly that they did on their dyno.
One reason for somone selling something to not do that is that it will show that flywheel lightening makes a significant differents in the lower couple of gears but almost no differance in the hiogher gears.
If it was a corvette you had this issue with then I would credit the example. I have no bog with a track only 426 hemi/68 dart/w6.13 gears and no bog in my forged 348 2001 vette. Why don't those examples count. By the way I am licensed in NYS to be a teacher....yes math although I don't teach which means nothing since you can juggle numbers all day long which still doesnt answer if the bog some people experience (and I don't) outweighs the very proven quick rpm run-up in gear. Further I like to resort to the inertia principle that states an obect at rest wants to stay at rest which is mass related. Reduce the mass both the rotating and the weight of the car and it has less inertia. You can't model everything that happens in a drag strip launch in a single equation that fits your need here. If you are trying to say that adding weight to the flywheel is going to make you run faster 1/4 times then go ahead and add the weight. I think your car bogged due to a poor choice in stroke for a drag motor.
I would like to point out from the very start of this thread I specified that this was not to be looked at from a drag race perspective.
I said exactly this:
If you change the flywheel to an aluminum one your car will be faster on the street where I said from the beginning that I don't do high rpm clutch dumps nor was I recommending it to those that do hard launches. There are guys on this forum who do use it on the track and they state they have no bog.
Jim, I want to be clear on one thing; I enjoy the debate
You know tuners read these threads but contribute nothing to them. They have flywheel experience and say nothing. The real rip-off is there, not in the writing but in the absence of sharing knowledge. How many guys on this board are running an aluminum flywheel and bothered to say how good it is? I get thanked by the ones that wont run these scam mods in the form of a kick in the azz for trying to turn this into a tech section instead of the listen-to-how-my-new-exhaust-sounds section.
I'm getting ready to be a read only member here.
I don't know anything about race cars but after listening to all of this, if I had to replace a clutch on my street-only C6, I'd put in the aluminum flywheel. It just makes too much sense. Most things that can be done to reduce weight also improve performance. This one seems like the rule and not the exception. Heck, I even remember a carbon fiber replacement for an aluminum driveshaft. I think that this was for some kind of Vette. Reducing driveline weight must mean a lot to some people.
I must confess that the "mass polar moment" thing has me stumped, though. I'm gonna hafta go watch March of the Penguins and call a math teacher to find out what that means.
As usual, thanks for the entertainment!
Dynos like Dynojets actually are just big flywheels with some instrumentation added. The readings you get from a Dynojet are calculated from how rapidly you acclerate the big ol' Dynojet flywheel.
