can you do this?
Old Jan 10, 2006 | 09:25 AM
tiger33's Avatar
tiger33
Default can you do this?
I had a nail removed from my left rear tire at Goodyear store. He jacked the car with a hand jack from the left side toward the back. He cracked the door saying that he heard that you should do that. Since the buzzer stayed on I closed the door while the car was up.
Question: Should the door remain open when it is jacked in this fashion and can you damage the frame?
I would like to buy a jack so I can check my tires for nails, etc. in the future.
Old Jan 10, 2006 | 09:36 AM
Buffy's Avatar
Buffy
No need to open the door. There were a few cars (like mid-60s British cars) that the door was hard to open once it was jacked up, so if you wanted it open it was easiest to do it before lifting it. This was due to a relatively flexible chassis. The C6 is very stiff, there should be no problem opening the doors (if needed) once it's raised.
The car should be lifted under the crossmembers as shown in the manual. It may be lifted under the frame, but care is required to avoid damaging the body panels. Jacking pucks are best for this purpose - they go into the shipping slots and provide a safe perimeter jacking point.
Old Jan 10, 2006 | 06:22 PM
jruss361's Avatar
jruss361
If a 186 MPH car is this flexible we are all in trouble.
Old Jan 10, 2006 | 06:28 PM
SA HEAT's Avatar
SA HEAT
Old Jan 10, 2006 | 07:18 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Old Jan 10, 2006 | 07:22 PM
wwashing's Avatar
wwashing
The C4 was the last Corvette the door should have been cracked on.
Old Jan 11, 2006 | 11:45 AM
Gman in NC's Avatar
Gman in NC
I remember a friend of mine telling me about his C4 being that way. If ever go through the Corvette Museum in BG take a look at the rolling chassis. It looks like a 3/4 ton truck frame. I jacked mine up from the sides a few weeks ago. Watched the door clearance while I did it. No movement.
Old Jan 11, 2006 | 01:03 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Which was rubish as well.
Old Jan 11, 2006 | 07:04 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
I owned a 1996 and the manual said nothing about opening the door but it did say to remove the roof panel to prevent it from cracking when the chassis flexed.
To can you do this?
