Z51 flaoting rotors
Old Jan 11, 2006 | 05:13 PM
NewC6Toy's Avatar
NewC6Toy
Default Z51 flaoting rotors
This post
http://forums.corvetteforum.com/show...ke&forum_id=74
said you could get the Baer rotors without cross drilling for the Z51 package. That is pretty much what I am looking to use for HPDEs, except the rotors are not floating. My experience has been that flaoting rotors really help handle expansion caused by heat. Also, I think it is easier to replace the rotor when the time comes.
Is Baer my only choice for 2 peice (flaoting or not) rotors for a Z51 package? I'm also curious if anyone has ever warped a set of Baer rotors?
Old Jan 11, 2006 | 05:58 PM
BgBoost1's Avatar
BgBoost1
Correct me if I am wrong....But isn't it the Caliper that is "Floating"??
Old Jan 11, 2006 | 06:21 PM
VET4LES's Avatar
VET4LES
Old Jan 11, 2006 | 07:14 PM
timd38's Avatar
timd38
I agree, the only thing I can think of is that the Baer rotors are two piece so the rotor is connected to the hub with a seperate piece. The Baer rotors weigh allot less than the stock Z51, but are they worth a $1,000?
Just a guess.
Old Jan 11, 2006 | 07:33 PM
NewC6Toy's Avatar
NewC6Toy
Yup, the caliper is floating, so if your rotor is a little warped or unevenly worn, it isn't a big deal. However, at the track, heat is the killer. At one point we had calculated how much energy was actually generated slowing a 3200 lb car 100mph was, it turned out to be much more than I expected. So most of that energy is dissapated as heat into you front rotors. Obviously, all that heat causes the metal to expand. One piece rotors will warp and crack because the center part is firmly fixed in place by the wheel, and the rest of the rotor is trying to expand. I used to go through a set of rotors in a weekend when I 1st started going to HPDEs, becuase they were warped so badly, they couldn't be turned. Floating rotors are mounted to the hat with bushings and have a little play in them to allow for expansion.
Old Jan 11, 2006 | 11:31 PM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
2 piece rotors are also refered to as floating
Old Jan 12, 2006 | 01:22 PM
NewC6Toy's Avatar
NewC6Toy
I guess you could say all floating rotors are 2 piece, but not all 2 piece rotors are floating. The picture below is from essexparts.com, who I am considering getting custom rotors from. The part I highlighted in red on the right is a bushing that allows the rotor to move some. Also, notice int the top right that the rotor has a slot for the bushing instead of just a bolt hole.
Old Jan 12, 2006 | 01:26 PM
davidfarmer's Avatar
davidfarmer
True race rotors are floating. Usually the hat is aluminum and the rotor steel, and they obviously expand at different races. The slot in the steer mounting bolt allows the hat and rotor to expand without binding each other up.
Even in solid steel rotors, the friction area is heated much more than the center, which causes some strange heat shock, causing cracks to form more quickly.
Old Jan 13, 2006 | 10:24 PM
54greg's Avatar
54greg
That was a really cool post! I've been a shade tree mech for over 40 years and I never really knew what a floating rotor was until I saw you pic.
Old Jan 14, 2006 | 04:55 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Get some Stoptech rotors from LGM
Old Jan 16, 2006 | 06:29 PM
Yody's Avatar
Yody
bump for a good thread
Old Jan 17, 2006 | 05:16 PM
bradb's Avatar
bradb
St. Jude Donor '06-'07
Great vendor. I used Essex for all my custom race car brake rotors and had super service. Express to them what your needs are and you can trust what they say.
To Z51 flaoting rotors
