Engine Oil.
Old Jan 19, 2006 | 08:53 PM
  #41
SERENITY_NOW's Avatar
SERENITY_NOW
Ok ... they call me the village oil idiot. I thought that a multi-viscosity oil meant that it had the combined flowing characteristics of the straight weight oils listed. So I thought that I would have the cold weather advantage of a 5W, and still have the track advantage of a 30W. So why not use a M1 0W-40W? Yes, I still hold the title above...
Old Jan 19, 2006 | 10:32 PM
  #42
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
The downside to mult-viscosity oils is that they need viscosity improvers, or VIs, to help them achieve those ratings. The VIs don't provide the protection of the basestock or the anti-wear additives. Plus, they can break down over time, so your 0w40 could turn into a 30 weight over time...
The good news is that good synthetics are essentially multi-viscosity without VIs, so they don't need as much VI as a petroleum based oil does. For example, a 10w30 synthetic might not need any VIs. But, it is reasonable to say that the larger the spread, the more VIs an oil has, and a 0w40 probably has a lot.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jan 20, 2006 | 04:14 PM
  #43
MitchAlsup's Avatar
MitchAlsup
Originally Posted by Subdriver
The downside to mult-viscosity oils is that they need viscosity improvers, or VIs, to help them achieve those ratings. The VIs don't provide the protection of the basestock or the anti-wear additives. Plus, they can break down over time, so your 0w40 could turn into a 5w40, or 10w40...
Actually the problem is that the 0W-40 break down into a 0W-30 or even a 0W-20. It is not the 'winter' number that get thicker, it is the operating number that reverts to the viscosity of the base oil.
Old Jan 20, 2006 | 09:20 PM
  #44
C66 Racing's Avatar
C66 Racing
Thanks Mitch. I edited my response based on what you wrote in the Oil Follies thread before I saw you had already posted here.
Old Jan 21, 2006 | 04:52 PM
  #45
MitchAlsup's Avatar
MitchAlsup
Just trying to be helpful
