transmission cooling question
any hints from anyone here what I might do or what trans cooler I might buy and from whom?
And yes there is a small fluid cooler on the back of the radiator for the Z51's autos, then it plugs into the radiator before going back to the tranny.
In the mean time replace the trans fluid with synthtic ATF and the diff with synthtic gear oil. That will help quite a bit.
I have a manual switch on my C5 to turn on the trans cooler pump and a switch to turn on the oil cooler / accusump. A must for dedicated track / race cars.
trans cooler has an electic pump in the right rear wheel well.
trans cooler left, AC condensor/ radiator center, oil cooler right
Accu-sump left front wheel well
DRM brake duct cooling extensions
any time additional cooling, engine, oil, trans, diff or brakes, that can be added it will help. No not a lower t-stat, as when you are driving that makes no difference.
Oh dont forget to blow out the radiators and ac condensor with a high pressure air hose to get the sand and dirt out. screens only keep grass and Mikky D cups out.
After one weekend on the track and this much dirt came out ( on floor)
Yes my C5 is a dedicated track HPDE car and I seldom drive it on the road. But any bit of additional cooling will help for street driving in hot climets.
