Dyno Charts
I am looking to do exauhst and intake on my coupe, and I need some help.
No, this is not another, "which is the best" post.
I have gathered that these may vary, but I am not looking for specific results.
I am hoping that someone may have dyno charts that they can post for an A6 coupe with only exauhst and intake mods...the brands are not important as I am only looking for "averages". I am really interested in seeing what the LS2 is able to do when it can breathe.
Thank you very much for all your help!
-Joe
you are looking at around 5hp for cat back and around 10 hp for intake give or take a couple here and there.
-Joe
It will be very difficult to find and/or compare A6 dyno numbers.
1. Because there is no 1:1 gear ratio
2. Simply because it is so new
Here is what turned up in a forum search of the user gallery for "C6 dyno timeslips":
http://forums.corvetteforum.com/phot...what=allfields
It doesn't work that way. The loss through your transmission and drivetrain can be calculated an an aggregate percentage loss, based on two measurements. Empirically, it is fairly predictable within a +/- tolerance. However, you can't apply the percentage in reverse (based on a single measurement) to obtain bhp.Let's use nice round numbers as an example...
Say you measured 100 bhp and 90 rwhp. The net drivetrain loss would be 10%, agreed? But if you add 10% to that 90, you won't have your starting number (100), but rather, 99.
I am by no means a math major but here goes. Divide the 330 by 400 and that will show you the percentage of the 400hp at the crank that is making it to the rear wheels. In your case 82.5 % so you are losing about 17.5% through the drivetrain. You would have to be making 448.5 Hp at the crank to achieve 370 hp at the wheels with a 17.5% drivetrain lose.
330/400 = .825 (% of power to the rear wheels)
so
400 = 330/.825
X = 370/.825
X = 448.5 hp
