Tire issues
Old Feb 1, 2006 | 07:40 PM
Bubba's C6's Avatar
Bubba's C6
Default Tire issues
Ok, nothing really major but I have a slow leak in my left rear. Looked and found a small screw in the middle of the tread. Do I have to replace the tire or can the EMT's that came on the Z51 package be plugged??
Thoughts..opinions welcome!
Thanks!
Old Feb 1, 2006 | 07:48 PM
aaaaa's Avatar
aaaaa
Plug it.
Old Feb 1, 2006 | 07:52 PM
Bubba's C6's Avatar
Bubba's C6
Thanks, I went to the local Goodyear tonight but their "RunFlat Tech" wasnt there. I am running it over to the dealer tomorrow to see if there is anything they can do.
Old Feb 1, 2006 | 07:57 PM
sallen619's Avatar
sallen619
Go back to Goodyear and have it repaired correctly for free.
Old Feb 1, 2006 | 08:00 PM
VET4LES's Avatar
VET4LES
Old Feb 1, 2006 | 08:02 PM
Bubba's C6's Avatar
Bubba's C6
So Goodyear over the dealer??? The onething they did mention to me at Goodyear was that if they plug the EMT, it would no longer work as a run-flat....should I be concerned with that??
Old Feb 1, 2006 | 09:08 PM
calemasters's Avatar
calemasters
That is an incorrect statement.
Old Feb 1, 2006 | 09:55 PM
tommyc5's Avatar
tommyc5
Lord please help me. Manager for a Kauffman Tire and an EMT is like every other Radial Tire. You NEVER plug a Radial tire with a tire Plug. The tire needs to be dismounted and patch from the inside. It is the only right way to repair a Radial Tire.
Old Feb 1, 2006 | 11:07 PM
Hoonose's Avatar
Hoonose
The correct runflat repair is a one piece combo patch-plug. Looks like a flattened mushroom.
And, of course, it is both a patch and a plug.
Check with GY on this.
Old Feb 2, 2006 | 12:27 AM
jimman's Avatar
jimman
I've had 8 flats in 236000 miles and all were patched from the inside with no problems at all.
Old Feb 2, 2006 | 12:28 AM
purple heart's Avatar
purple heart
i believe that process is called "vulcanization" or, vulcanized.
Old Feb 2, 2006 | 07:59 AM
z51dcs's Avatar
z51dcs
tommyc5 is correct. From a guy in the tire business for many years (me), you dismount and plug patch it from the inside. The plug patch is so light weight that a rebalance is not usually required if they lightly mark the tire and wheel with a grease pencil before disassembly and then line the marks up after completing the repair. Service and driveability should not be degraded from the puncture as you describe it, runflat with the tire after the repair should be fine.
Old Feb 2, 2006 | 08:40 AM
Walt White Coupe's Avatar
Walt White Coupe
Baloney on the rebalance. Always rebalance if the tire is dismounted.
Old Feb 2, 2006 | 10:21 AM
Hoonose's Avatar
Hoonose
5 flats in 32,000 miles and all were patched w/o trouble.
Old Feb 2, 2006 | 10:22 AM
Hoonose's Avatar
Hoonose
Sounds sensible, but I never rebalanced after 5 repairs and never had any hint of a problem at any speed.
Old Feb 2, 2006 | 02:35 PM
catbert's Avatar
catbert
Discount Tire has always rebalanced after fixing the flats on my C6 - all for free.
Old Feb 2, 2006 | 05:18 PM
V8 Juice's Avatar
V8 Juice
Just curious, how the heck did you get 5 flats in 32K miles? I've run C4, C5 and now C6 since 1986, easily 320,000 miles and never had a flat, even with some track time.
To Tire issues
Old Feb 2, 2006 | 05:28 PM
davidfarmer's Avatar
davidfarmer
last time I checked, only one EMT dealer, and they're over an hour away.
I plug ALL of my tires, and have had no problems
Old Feb 2, 2006 | 05:50 PM
aaaaa's Avatar
aaaaa
I have plugged bias ply, radial car & motorcycle tires for over 30 years and have not had a problem. In fact just recently I picked up a 'wing' bolt (toggle) in the RR which already had a plug in it. The hole was so large I needed two plugs. That was two weeks ago-no problems
Tire manufacturers don't want the liability and they want to sell tires-what do you expect them to say? A simple hole with only minor damage to the tire requires a repair that will hold pressure-that's all.
Old Feb 2, 2006 | 06:23 PM
SickRick's Avatar
SickRick
In florida, I believe it's against the law to for a licensed garage to shoot a plug into a tire. I've picked up a number of foreign objects in my rears recently (GS-2 EMT's), and had both pulled, patched from the inside, remounted & rebalanced. At what I'm (we're) paying for tires, it's probably better in the long run to do the correct repair, than not.
YMMV
Rick
