Tire issues
Old Feb 2, 2006 | 06:48 PM
rcw1776's Avatar
rcw1776
Cruising
If you have had the car less than 1 year I would take it back to the dealer you purchased it from. They should replace it for free.
Old Feb 2, 2006 | 07:20 PM
Hoonose's Avatar
Hoonose
Originally Posted by V8 Juice
Just curious, how the heck did you get 5 flats in 32K miles? I've run C4, C5 and now C6 since 1986, easily 320,000 miles and never had a flat, even with some track time.
Construction around my house. I seem to pick up screws and nails dropped in the street.
Old Feb 2, 2006 | 08:07 PM
robvuk's Avatar
robvuk
Originally Posted by aaaaa
I have plugged bias ply, radial car & motorcycle tires for over 30 years and have not had a problem. In fact just recently I picked up a 'wing' bolt (toggle) in the RR which already had a plug in it. The hole was so large I needed two plugs. That was two weeks ago-no problems
Tire manufacturers don't want the liability and they want to sell tires-what do you expect them to say? A simple hole with only minor damage to the tire requires a repair that will hold pressure-that's all.
Same here. I will add to that by saying I have over 300,000 miles total on all the Vettes that I've owned. Never did anything but plug them. If the hole is too big to plug, you need a new tire. I've roadraced on tires with plugs and never had a problem. To each his own. If it makes you feel better, patch it.
Old Feb 3, 2006 | 02:35 PM
aaaaa's Avatar
aaaaa
Quote: ---At what I'm (we're) paying for tires, it's probably better in the long run to do the correct repair, than not.
Not to argue but that is exactly the point of this post-what is correct?
Obviously you think the only 'correct' repair is a patch. I don't agree.
Old Feb 4, 2006 | 12:03 PM
V8 Juice's Avatar
V8 Juice
Understand; I think there is a law that contractors have to throw a bucket of nails on the road at every construction site. Sorry about your experience.
Old Feb 4, 2006 | 12:42 PM
Hoonose's Avatar
Hoonose
Could have been worse if I didn't have runflats. With all but one flat I was able to limp to a tire store for repairs. The other flat, I had a guy do a simple plug from the outside, just to get me home, about 30 miles. I probably could've carefully driven home.
