2005 Power Top Problems
Old Feb 6, 2006 | 06:50 AM
winron43's Avatar
winron43
4th Gear
Default 2005 Power Top Problems
Top will not go down when button pushed. Dealer is having difficult time fixing. Has put new module in and still does not work. Anybody else having power top problems?
Old Feb 6, 2006 | 08:51 AM
z51dcs's Avatar
z51dcs
This is new to me. I got my 05 Vert with everything BUT the power top because I was told by a large volume vette dealer that chevy was having "sequencing problems" with the top, ie. the top sometimes didn't perform the several steps required to raise or lower the top in the correct order, with the result that the top just didn't operate.
Old Feb 6, 2006 | 12:28 PM
scrannel's Avatar
scrannel
No problems with my '05 power top. But I have heard of some tops binding because of misaligned assembly. Try a search.
Old Feb 6, 2006 | 01:41 PM
winron43's Avatar
winron43
4th Gear
Default Power Top 2005
Car is at dealer. They are talking to GM tech services for help.
Old Feb 6, 2006 | 11:20 PM
purple heart's Avatar
purple heart
well, I had a similiar problem but it happened only after the battery went dead; after I charged it up, I then disconnected the battery for about 3-5 mikes, reconnected it and Whalaa! It worked. Someone said something about the computers recycling after the dead battery ordeal, and it worked fine after the 3-5 min. diconnect.
*If you don't have the dead battery issue, just try the battery disconnect anyway-nothing to lose and, well, you know the rest...
Good Luck(a shot in the dark)
Old Feb 6, 2006 | 11:52 PM
tfenton's Avatar
tfenton
Early on I had HUGE power top issues. 3x back to the dealer and for the first 3 months of ownership the dealer had the car for probably 3 weeks in total.
First issue was solved by new switches. The second switches failed again. Had them replaced. Third problem arose when the cover became mis aligned and the ragtop hit the cover before it fully opened and then the operation would completely shut down. Oh, loads of fun. Thank goodness for the manual over ride!!!
Upon third trip to the dealer, they replaced all hardware for the cover latches (that was about another week in the shop).
And, by the way, since I have an amp and subwoofer I had to pull both out of the trunk and ground the wiring before they would touch the car.
Royal pain in the **** and was seriously thinking of dumping the car. But, after the 3rd fix I've never had a problem and the car has been pure excitement.
Old Feb 7, 2006 | 06:13 AM
winron43's Avatar
winron43
4th Gear
Thanks for the replies. Yesterday GM tech told the dealer to replace the body control module and reprogram
Old Feb 7, 2006 | 08:50 AM
MyRedC6's Avatar
MyRedC6
Guess that I am lucky in that I have not had any issues with my top
Old Feb 8, 2006 | 11:15 AM
scrannel's Avatar
scrannel
Exactly how do you get to the manual over-ride?
Old Feb 8, 2006 | 11:27 AM
tfenton's Avatar
tfenton
First, don't read the owners manual! In the onwers manual it says the override is in the engine compartment. Wrong end of the car.
The override is actually in the bay where the ragtop is stored on the passenger side. With the top half open, peel back the carpeting on the passenger sidewall in the bay. You will see the a hex wrench appended to the unit. Use the hex wrench and turn the dial about halfway around. This releases the compression and you can now move the top and cover manually.
Old Feb 8, 2006 | 11:56 AM
scrannel's Avatar
scrannel
Thanks!
Old Feb 8, 2006 | 05:31 PM
winron43's Avatar
winron43
4th Gear
Power Top - Ended up being a micro sensor on one of the frame rails of the top that was bent over telling the computer not to open because something was in the way. If anybody is having the problem, have them call Scott Hendrix - Service Manager at Branch Chevrolet in Fort Myers, Fl. He's got the knowledge now.
Old Feb 9, 2006 | 12:20 AM
jkonkle's Avatar
jkonkle
Go big or don't go...
yah there are little switches all over the place - the hydrolic lines are smaller than a number two pencil.
also, make sure the dealer calls' GM tech support.
JK
Old Feb 9, 2006 | 12:22 AM
jkonkle's Avatar
jkonkle
counter-clockwise is the direction to turn it. however, this is only helpful if the top is DOWN. If the top is up and you are trying to take it down - wait - why would you do that? <shrug>
I learned today that if the top is manual-lowered and the hydro pump release screw is tightend the powertop will not go up with power. You have to manually raise it and then it will "power down" - this was upon cycling the battery due to battery drain.
Just thought I'd share that.
JK
Old Feb 9, 2006 | 12:57 AM
vjones's Avatar
vjones
No problem here knock on wood
Old Feb 9, 2006 | 10:18 AM
benspruce's Avatar
benspruce
I've had two problems: first a microswitch failed. I learned the hard way that when one fails replace both of them. Second, tonneau would not go up and I had some hydraulic fluid on my garage floor. The problem was the motor that drives the hydraulic system was bad and was blowing seals. Dealer replaced unit and all was well. It's great when the top works as it should, but it was a pain getting there.
Old Feb 11, 2006 | 10:55 AM
clouddancer's Avatar
clouddancer
Default just '05 or also '06?
Hey guys, are the above problems all with '05's or also with '06's? My '06 is being built on Monday with pwr top. I went back and forth over pwr vs. manual top and hope I did not make the wrong choice.
To 2005 Power Top Problems
Old Feb 11, 2006 | 12:55 PM
scrannel's Avatar
scrannel
Not sure. Heard they made some physical changes, not sure about electronics. But the power top problems appear to be a minor issue.
Old Feb 11, 2006 | 02:42 PM
benspruce's Avatar
benspruce
My power top issues were minor and easy to fix. It's just that it took several trips to the dealer. Now that it has been working as it should I really enjoy the option. BTW, this has been my only problem with my 05 vert. It has been great fun. Now has 8k miles.
Old Feb 11, 2006 | 05:06 PM
StrayDog's Avatar
StrayDog
Veteran: Marine Corps
I will be getting a C6 Convertable with all options except... the folloewing , #1 Power Top $2k , To put the top down ???, #2 Onstar not for me, #3 Navigation , dont get lost often & I like ***** on my radio & other places.......... The Dog.
