TSB for transmission hunt problem
Old Feb 9, 2006 | 07:26 PM
MannyS's Avatar
MannyS
Default TSB for transmission hunt problem
I looked everywhere using search and I cannot find the TSB on the 06 C6 A6 transmission "hunting" for gears problem.
Thanks.
Old Feb 10, 2006 | 07:29 AM
SC TROJAN GRAD's Avatar
SC TROJAN GRAD
ttt
Old Feb 10, 2006 | 08:06 AM
MyRedC6's Avatar
MyRedC6
Try 06.07.30.002
Old Feb 10, 2006 | 11:30 AM
TN 2005 C6's Avatar
TN 2005 C6
Cruise-In VI, VII & XII Veteran
St Jude Donor '07-'08-'09
I not usre if this is the one you want but here is a link: http://corvetteactioncenter.com/kb/q....php?qstId=599
Old Feb 10, 2006 | 11:33 AM
MannyS's Avatar
MannyS
Thanks to both of you. This is what I am looking for. My co-worker went to NY last week in her A6 C6 and she experienced the transmission delay issues when it was below freezing.
Old Feb 10, 2006 | 11:47 AM
CorvettePartsBob's Avatar
CorvettePartsBob
Mannys,
Here is the actual bulletin from GM. I hope this helps.
Bob
Document ID# 1741321
2006 Chevrolet Corvette
Automatic Transmission, Busy Shifting, MIL Illuminated, DTC P1751 - keywords 3-4 4-3 4-5 5-4 5-6 6-5 6L80 body busy fifth fourth MIL MYC sixth third valve valvebody #PIP3649 - (Dec 9, 2005)
2006 Cadillac XLR-V and STS-V
2007 Cadillac Escalade
2007 GMC Yukon
Equipped with 6L80 (RPO - MYC) Automatic Transmission
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may experience busy or frequent up and down shifts in 3rd, 4th, 5th or 6th gear at approximately 30-50 mph. The MIL may also be illuminated and a DTC P1751 stored in the TCM.
Recommendation/Instructions:
These conditions may be caused by an undersized hole or debris in the control valve body spacer plate.
To correct this condition the control valve body spacer plate must be replaced. These parts are not currently available from GMSPO and must be obtained by contacting Technical Assistance. If the control valve body spacer plate is required a complete valve body assembly including TCM will be sent to the dealer at no charge.
Service Procedure
Refer to SI document # 1670458 - Control Valve Lower and Upper Body Replacement for the proper procedure. The TCM must be programmed after installation of the control valve body assembly, refer to SI document # 1466621 - Transmission Control Module Programming and Setup. Service Fast Learn Adapts must also be run, refer to SI document # 1688788 for that procedure.
Warranty Information
Labor Operation
Description
Labor Time
K9505
Valve Body Replace
1.5 hrs
add:
Diagnosis
0.0 - 0.3 hrs
This labor operation includes time to program the TCM and perform Service Fast Learn Adapts. The part will be shipped to the dealership at no charge, a parts handling allowance of $120.00 may be added to the warranty claim as a net item.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Old Feb 10, 2006 | 12:04 PM
MannyS's Avatar
MannyS
Thanks Bob. I just emailed this TSB to the service writer at the dealership servicing her car.
Old Feb 11, 2006 | 02:41 PM
custom124's Avatar
custom124
Thanks.
i had the same problem, a real pain in the ***. here is the link and info on the problem, got mine fixed last week, what a difference, Ray http://www.corvetteactioncenter.com/....php?qstId=600
Old Feb 11, 2006 | 05:48 PM
MannyS's Avatar
MannyS
custom124 - what were your transmission symptoms?
To TSB for transmission hunt problem
