LS2 MAF question
Old Feb 11, 2006 | 10:10 PM
Skunkworks's Avatar
Skunkworks
Default LS2 MAF question
Just doing some research and wondering what size LS2/7 MAF is, also if possible max frequency and flow?
This is to see if C6 MAF can be made to work on C5 with supercharger.
Thanks in advance,
Mike
Old Feb 12, 2006 | 03:14 AM
SpinMonster's Avatar
SpinMonster
The C5 2001+ LS1 and C6 LS2 MAF are identical. The LS6 MAF is the same unit without a screen. The Ls7 is a different sensor with no housing.
Old Feb 12, 2006 | 04:20 AM
Jagcvette's Avatar
Jagcvette
LPE just puts a ported and polished throttle body on their engine packages.
Old Feb 12, 2006 | 09:18 AM
davidfarmer's Avatar
davidfarmer
the OEM table goes up to 511gms/sec
Old Feb 12, 2006 | 02:52 PM
Skunkworks's Avatar
Skunkworks
Thanks guys, I was hoping LS2 may have larger them my 85mm MAF, especial when considering 90mm TB. On my system MAF is going to be most restrictive piece do to draw through installation.
Any detail on LS7 MAF, or is it still 85mm?
Thanks,
Mike
Old Feb 12, 2006 | 03:14 PM
Redline Motorsports's Avatar
Redline Motorsports
Skunk,
If you really feel the MAF is a restriction, maybe you should junk it and tune the car in speed density.................you will probably get a better tune!
You could also use a FORD MAF as they also work on a 5 volt reference. You would just need to know the scaling. All the MAF is, is a simple measuring input. The PCM just reads the voltage to determine load.
Old Feb 12, 2006 | 03:40 PM
Skunkworks's Avatar
Skunkworks
Originally Posted by 9D9LS1
Skunk,
I will eventually move to speed density. C5/6 PCMs expect a frequency and not voltage proportional to mass flow. Ford uses voltage if I’m not mistaken.
Mike
Old Feb 13, 2006 | 02:37 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Thanks in advance,
Mike
Mike,
The LS2 maf is scaled from 1000 Hz to 12200 Hz with the calibration from 2.95 g/sec to 511.99 g/sec.
Charlie
Old Feb 13, 2006 | 02:27 PM
Skunkworks's Avatar
Skunkworks
Thanks Charlie
Mike
To LS2 MAF question
