Corsa Question Need Advice
Old Feb 14, 2006 | 05:00 AM
S281ER238's Avatar
S281ER238
Default Corsa Question Need Advice
i just installed my corsa sports 2 weeks ago love them love the sound and quility on my c6 2006 z51 but when i drove it after install i noticed the car felt a little heavy in the rear and we i got on it it didnt have the same pull that the stock cat back hat it felt like i had gained more weight to the rear anyone else had felt this or is it just me i think corsa are heavy com to stock will this effect a little of the performance as far as pull tq on the car
Old Feb 14, 2006 | 08:13 AM
davidfarmer's Avatar
davidfarmer
they are heavier, but not enough to feel once installed. The weight is almost directly over the rear axle, so would actually improve weight bias.
Old Feb 14, 2006 | 08:39 AM
Turbooo2u's Avatar
Turbooo2u
Hopefully they have more exhaust flow to offset any weight gain.
Old Feb 14, 2006 | 09:28 AM
6speedC6's Avatar
6speedC6
Damn your sensitive enough to feel that little weigh gain you should be driving NASCAR!!!!
Old Feb 14, 2006 | 09:37 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
The weight difference is about what 3 gallions of gas come to.
Do you notice much of a difference when you use or add gas?
Old Feb 14, 2006 | 10:32 AM
davidfarmer
in his defense, the fuel tanks are in front of the rear axles, but the mufflers are behind the rear axles. Therefor, it would be more like 3.1gal of gas
of course I'm just being silly
Old Feb 14, 2006 | 11:22 AM
jazzlove's Avatar
jazzlove
From: San Antonio Texas - Any sufficiently advanced technology is indistinguishable from magic
No sh**....!!
Old Feb 14, 2006 | 12:10 PM
SpinMonster's Avatar
SpinMonster
Your post said that you needed advice. What is the question? You want to know if you should go back to stock?
Old Feb 14, 2006 | 01:44 PM
catbert's Avatar
catbert
.....or a crew chief.
Old Feb 14, 2006 | 02:39 PM
S281ER238's Avatar
S281ER238
dont know just feels hevy in the back
Old Feb 14, 2006 | 04:23 PM
Turbooo2u's Avatar
Turbooo2u
I hope it ain't 3 gallons...thats like 30 or 40 lbs.
Old Feb 14, 2006 | 04:55 PM
Turbooo2u's Avatar
Turbooo2u
Did some research. The Corsa Sports weigh 3.5lb per side total than stock. 7lbs. And I've read a review from "Vette" magazine, June 2005. Apparently, the system is good for about 13RWHP as tested by MTI racing on a stock Z-51 coupe. I believe Lingenfelter testing also confirmed this.
Old Feb 14, 2006 | 11:23 PM
purple heart's Avatar
purple heart
Default Question here...
If you added a Corsa X-Pipe to the Corsa Sports, leaving the OEM cats and exhaust manifolds on, could that actually make the car "feel" slower than when it had the H-Pipe(oem) on? I know they are used with headers but can the X-Pipe have a negative effect on the "power" feel and actually reduce torque causing the car to "feel" slower than before at WOT?
Old Feb 15, 2006 | 07:45 AM
Burnt C6's Avatar
Burnt C6
2023 Corvette of the Year Finalist - Unmodified
2022 C5 of the Year Winner - Unmodified
Cruise-In X Veteran
St. Jude Donor '08 thru '11,'22 thru '26
Gasoline weights 6.216 Lb. per gallon there for 3 gallons would weigh 18.648#
Old Feb 15, 2006 | 09:32 AM
6spdC6's Avatar
6spdC6
I know when I put them on, they felt like they were much more than the stockers. I read somewhere that the difference was about 15 lbs.
That is why I said about 3 gallons of gas. In plain English not a big deal for MOST drivers out there. The major difference which I like is the "no drone".
To Corsa Question Need Advice
