3rd Gear Shift???
Old Feb 17, 2006 | 08:51 PM
BIGGGIE's Avatar
BIGGGIE
St. Jude Donor '05-'06-'07-'08
Default 3rd Gear Shift???
Has anyone have problems with a 2-3 shift? Feels like it goes into the gear but then nothing happen's....and it always happens to me like in a 5900-6100 rpm shift...But works fine at like 4500-5500 ..?
Old Feb 17, 2006 | 09:51 PM
redhot6's Avatar
redhot6
This is a problem for many of us.
Old Feb 17, 2006 | 09:53 PM
05_C6Z51's Avatar
05_C6Z51
Me too. Someone here suggested the open palm technique which allows the shifter to lign itslef up. Originally, I thougth that was hogwash but have been very pleased with the result.
Old Feb 17, 2006 | 10:00 PM
blkc6z51's Avatar
blkc6z51
This technique works good.
Old Feb 17, 2006 | 10:13 PM
cerino2000's Avatar
cerino2000
hmm..I thought it was just me. Happened to me on the track once and on the street once. It seemed to go to nowhere land. Felt like it went into gear, just took a little more umph but it just went....well, not a clue, but not into third.
Old Feb 17, 2006 | 11:31 PM
Big Ron 77's Avatar
Big Ron 77
Shifting fast from 2-3 is definitely an open palm shift, no forcing, it tracks easier.
Best idea, buy another shifter...B&M is supposed to be good.
Old Feb 18, 2006 | 02:33 AM
BIGGGIE's Avatar
BIGGGIE
Thanks for the feedback though maybe my pressure plate was going bad or something like that...someone else told me that at the track the other night just to use my wrist .palm open. but i still missed 3rd 3 times...best time was 12.80@114.00 60 foot was 2.18..need tires mine about almost bald...
Old Feb 18, 2006 | 11:01 AM
Wass's Avatar
Wass
St. Jude Donor '09-'11
I had the same problem on occasion until I used the open (relaxed) palm shift and let the centering spring do its thing. However, sometimes I would forget and try to slam third with a firm grip. Whenever I would do this, I risked hanging it up without hitting 3rd. So I went with the B&M shifter...Problem solved. If you can consistently shift up to 3rd with a relaxed palm, you will most likely never miss this shift. Problem was I couldn't always do it.
Old Feb 18, 2006 | 11:12 AM
TrackNoob's Avatar
TrackNoob
for your 2-3 upshift only, do the following:
1. With hand on ball of shifter while accelerating through second gear,
2. Unwrap your fingers,
3. Point all fingers straight to roof. This will 'lock' your wrist (try it now)
4. Now, when you reach your shift point, just push sharply FORWARD with the meaty part of your palm, as fast as you can. Don't be hesitant! Do not try to direct the shift to a gate. Leave your fingers up and off the shifter during the shift.
I have yet to miss a 2-3 shift this way, and I had lots of trouble before. It now feels almost as good as the good old comfortable 1-2 'yank straight back' that we all know how to do with no trouble.
Old Feb 18, 2006 | 01:01 PM
Walt White Coupe's Avatar
Walt White Coupe
This shift couldn't be more simple. Just push staight forward from second and the mechanism will drive you into third. No side pressure. Same with 4th to 5th. Straight back, no side pressure.
Old Feb 18, 2006 | 01:27 PM
Big Ron 77's Avatar
Big Ron 77
Are you power shifting? 2 to 3 is much harder when power shifting for the tendency to force. B&M!!!! Not that it will save the synchros over time, but hey, what's money for?
Old Feb 18, 2006 | 05:22 PM
Steve Germany's Avatar
Steve Germany
B&M is good but the Callaway is heaven!
Old Feb 19, 2006 | 09:44 AM
k-line's Avatar
k-line
This happened to me a few times the first couple months after I got the car. But not once in the last 10 months. I'm not sure what I'm doing different, maybe just not rushing my shifts so much.
Old Feb 19, 2006 | 11:04 AM
midnite902's Avatar
midnite902
Main reason I went to the B&M.
Old Feb 19, 2006 | 11:07 AM
05_C6Z51's Avatar
05_C6Z51
I have the B&M and still need to open palm it.
Old Feb 19, 2006 | 12:44 PM
midnite902's Avatar
midnite902
I do not "open palm" any shift and have not had the problem since switching to the B&M. Also switched from Redline to Synchromax and shifts feel smoother but hate to post "feels".
Old Feb 20, 2006 | 08:37 PM
BIGGGIE's Avatar
BIGGGIE
Thanks Guys i will give it a try...When i run my car this weekend..So i should also look into the B&m or callaway..Do they take the stock ****? or i need a diffrent one...can i see a picture of the callway in your car(STEVE GERMANY) and the B&m(MIDNITE902) also?
To 3rd Gear Shift???
Old Feb 20, 2006 | 08:45 PM
midnite902's Avatar
midnite902
You can not tell the difference from OEM appearance with the B&M.
Old Feb 20, 2006 | 09:04 PM
schilitj's Avatar
schilitj
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Erick
Just ordered AFT 225 heads from Andy at A&A Corvette in CA. They should be here early next week. Roger will get the rest of the equipment, 224 228 LSA114 cam, underpulley etc. When it is done, Mike Norris will tune and dyno it. Then, off to the track!
Jeff
Old Feb 20, 2006 | 11:50 PM
BIGGGIE's Avatar
BIGGGIE
cool let me know when its done i want to be there...
