Installing Headers...wish me luck!!
Old Feb 21, 2006 | 09:43 PM
valdeztke's Avatar
valdeztke
Default Installing Headers...wish me luck!!
Well I will be getting my Dynatech Supermax 17/8 longtubes with cats
and a ...hmmm ....oh yeah a Halltech C6 Stinger.
Can anyone offer me any advice .. I am doing the install this weekend myself and could use all the help I can get Yes I will have access to a full machine shop lifts and air tools (pneumatic?) ...
Dave, RDF, and a few others have given me advice ....but I am in the Northern Virginia area and anyone that wants to turn a wrench and has nothing to do this weekend ....or wants to get away from anything he has to do ( the wife, chores, the kids ..etc) you are welcome to lend me a hand!!
Also I am going to write up a nice DIY on the intake and the headers ..
all professional and stuff
Old Feb 21, 2006 | 09:59 PM
schilitj's Avatar
schilitj
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
good luck, I have the same setup plus Corsa sports. Getting heads and cam next week. It's a long drive from Boca Raton, FL to N VA! And, you guys have snow, yes?
Old Feb 21, 2006 | 10:01 PM
Mayonayze's Avatar
Mayonayze
From: Prepare yourself, for a pride obliterating bich smack. Fairfax, VA
St. Jude Donor '06-'07-'08
SEC > BCS 4 St. Judes '09
you know i'm gonna try to be there! werd!
Old Feb 22, 2006 | 02:04 AM
jkonkle's Avatar
jkonkle
Go big or don't go...
PM HalJensen; he did this about six months ago and has some tips I'm sure!!
JK
Old Feb 22, 2006 | 08:08 AM
valdeztke's Avatar
valdeztke
Nah not alot of snow..it has snowed twice and is in the 50's now.
I did pm him.
Thanks guys!
Old Feb 22, 2006 | 09:01 AM
fastskyline's Avatar
fastskyline
only tip i can really give you is take your time and be very careful when re-installing the header bolts. getting one cross threaded would be very expensive. good luck!
Old Feb 22, 2006 | 09:46 AM
CYA-Vett's Avatar
CYA-Vett
Piece of cake, nothing to worry about....
Old Feb 22, 2006 | 09:58 AM
valdeztke's Avatar
valdeztke
Hmm anyone know what to TRQ them to?
Well thanks CYA...we shall see!!!!
Old Feb 22, 2006 | 10:12 AM
CYA-Vett's Avatar
CYA-Vett
18 ft/lbs
Old Feb 22, 2006 | 10:15 AM
fredgpowell's Avatar
fredgpowell
I would drive to Northern Va to get you to help put mine on also. Want to make a deal on that. I iwll help you if you help me and I will drive down and make it happen. I have some LGs and a vararam intake.
Old Feb 22, 2006 | 10:16 AM
valdeztke's Avatar
valdeztke
Hints;
1. Pay attention to the directions.
2. Be sure and install the clutch line bracket BEFORE you install the drivers side header.
3. Triple check the exhaust manifold gaskets orientation before you torque them down, if they are wrong you can't install the sparkplugs.
4. Be carefull with the O2 sensor wire routing, the instructions are vague.
5. Watch the torque settings, most are well below what air tools usually give.
6. Use anti-seize on the header bolts and spark plugs.
i got this from haljensen. THANKS!!!
Trust me I am going to put together a nice DIY with a buttload of pics!!!
Old Feb 22, 2006 | 10:28 AM
valdeztke's Avatar
valdeztke
Thats like 8 hrs!!
Let me attempt a few down here first...
Once I get comfortable I will do a set every weekend for free
I live to work on cars ... and it gets me away from the fiance for a valid reason. She is a car fanatic too! but doesnt like to get dirty!
Old Feb 22, 2006 | 12:52 PM
serendipity's Avatar
serendipity
I'll probably have some time Saturday if you need a hand. I think I'll be getting LGs shortly. Not sure if I want to do them myself or just have a shop take care of it...
Old Feb 22, 2006 | 01:14 PM
OWENMUSTANG's Avatar
OWENMUSTANG
this might help...
i have dynotech headers on my ls1 camaro.
one of the problems (many) i had with these are the flange bolt holes.
on 2 different sets of heads, the bolt holes are slightly different than the heads.the drivers side was just minor problem, the pass side would bind the header bolt either side of dead center no matter how you aligned the header. i ended up enlarging the holes 1 drill size to fix...
a major pita after you get the header in...
Old Feb 22, 2006 | 01:45 PM
cmb13's Avatar
cmb13
Good luck. I'm interested to see how it works out. I love projects like this!
The best tip I've heard is to make sure you use a torque wrench and don't overtighten the bolts.
Old Feb 22, 2006 | 01:48 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
I have lgs to install
Old Feb 22, 2006 | 01:51 PM
Mayonayze's Avatar
Mayonayze
at taxachussettes. didnt make out too well this year on the state return i take it?
valdeztke, i should be on the halo tonite. if i see you on, we can jump in a party and discuss the details for this weekend.
To Installing Headers...wish me luck!!
Old Feb 23, 2006 | 01:41 AM
U2bassAce's Avatar
U2bassAce
St. Jude Donor '06
Good Luck!!!!
Old Feb 23, 2006 | 03:21 AM
Brabus2's Avatar
Brabus2
Good luck, hope all goes well!!!
Old Feb 23, 2006 | 04:22 AM
S281ER238's Avatar
S281ER238
Installing Headers Like Kooks Will It Cause Check Engine Lights Or Any Problems When Going To Dealer
