Fast intake
Old Feb 22, 2006 | 12:23 PM
mo-shy's Avatar
mo-shy
Default Fast intake
What is Fast intake is it like the normal Air intake?(LPE,Stinger...etc)
if i want install that Fast intake must be tend my After market Air intake?
i am nwebie i dont have experience in performance world
any one have idea ?
Old Feb 22, 2006 | 12:27 PM
Mayonayze's Avatar
Mayonayze
From: Prepare yourself, for a pride obliterating bich smack. Fairfax, VA
St. Jude Donor '06-'07-'08
SEC > BCS 4 St. Judes '09
intake manifold (plenum) that sits over the heads. it sits behind the CAI and throttle body.
Old Feb 22, 2006 | 12:30 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Here you go
http://www.lingenfelter.com/Merchant...Category_Code=
It replaces the black intake manifold on top of the motor. You will need to make adjustements to the firewall or the intake manifold itself. LPE sells a kit to modify the firewall and it fairly straightforward and simple.
Old Feb 22, 2006 | 12:33 PM
sunsetZ51's Avatar
sunsetZ51
go to http://www.powerandperformancenews.c...ry_Code=LSXCMF this will answer it for ya
Old Feb 22, 2006 | 01:45 PM
SpinMonster's Avatar
SpinMonster
Such confusion could only happen in the corvette world.
Intake....not your fault though.
Actually a local BBQ dealer sells some models he calls...cooking stations.
Old Feb 22, 2006 | 01:59 PM
cmb13's Avatar
cmb13
Here are the questions you need to ask next:
How much power will the intake manifold / Fast intake produce?
How does it compare to a CAI?
How 'bout the two together?
I'm listening too...
Old Feb 22, 2006 | 02:02 PM
cmb13's Avatar
cmb13
Also, will this affect the warranty?
Is it compatible with other intakes?
Compatible with supercharger?
Is reprogramming necessary after installation?
Dyno results?
1/4 mile results?
Old Feb 22, 2006 | 02:11 PM
CamaroCane's Avatar
CamaroCane
Also, will this affect the warranty?yes
Is it compatible with other intakes?yes
Compatible with supercharger?yes, unless a roots type blower
Is reprogramming necessary after installation?no, but probably recommended
Dyno results?dont know
1/4 mile results?don know
Old Feb 22, 2006 | 02:16 PM
Mayonayze's Avatar
Mayonayze
spoke with a local tuner about this very matter, and he says that it really depends on the dealer (like all mods). he considers it a fairly straightforward bolt-on, but not as widely overlooked or ignored by dealers as things like CAI's, catbacks, and headers. for whatever that's worth. *shrug*
Old Feb 22, 2006 | 02:54 PM
cmb13's Avatar
cmb13
That's what I'd suspect. Getting awefully close to the actual block.
Old Feb 22, 2006 | 05:42 PM
saplumr's Avatar
saplumr
Stock throttle body will have to be replaced on supercharged engine.
Old Feb 22, 2006 | 08:52 PM
NineBall's Avatar
NineBall
Most stock LS2's pick up around 12-15 rwhp with an FAST intake manifold swap. Some guys sand off the logo and spray paint them flat black and they look factory. Gotta have a good eye to spot the stealthy ones.
BTW, I still have a FAST intake for sale.
Tony
Old Feb 23, 2006 | 12:05 AM
rmitchell242's Avatar
rmitchell242
i have fast intake no warranty issues here
Old Feb 25, 2006 | 07:15 PM
mo-shy's Avatar
mo-shy
Thanks, now i have i dea
but what the diffrent between 80mm and 90mm? which one give more hp?
Old Feb 26, 2006 | 12:41 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Nice exhaust Video. Would be mo betta if you did a burn-out after getting in the car. Smoke 'em Baby
To Fast intake
