180 T'stat help, please
Old Feb 22, 2006 | 05:15 PM
EuroRod's Avatar
EuroRod
Default 180 T'stat help, please
Where can I find a 180 t'stat for the C6. I've found plenty of vendors for a 160, but can't find a 180. Thanx.
Old Feb 22, 2006 | 10:39 PM
cbrf4i1's Avatar
cbrf4i1
i don't recall the name, if u do a search, you should be able to find it...it will run you alot more than the 160 stat.
Old Feb 22, 2006 | 10:59 PM
67Roadster's Avatar
67Roadster
All of the main parts houses have it such as Zip and other forum venders
Old Feb 23, 2006 | 01:13 AM
eilgs22000's Avatar
eilgs22000
7th Gear
Why would one put in a 160 or a 180 thermostat? Is there such a big difference in performance results or some other reason of installing one over another?
Old Feb 23, 2006 | 08:29 AM
CYA-Vett's Avatar
CYA-Vett
Just get the 160, the fans control the upper temp anyway
Old Feb 23, 2006 | 08:55 AM
fredgpowell's Avatar
fredgpowell
Old Feb 23, 2006 | 11:09 AM
andreas g.'s Avatar
andreas g.
Default Why 180
The factory temp stat is 186.6 degrees. Why get one 8 degrees cooler.
I'm running a 160 as I've run in all my LS type motors, and the car runs on the highway between 178-183 degrees. With tunning which cycles the fans by % at different temps in C6's, the car runs in town in the 178-190 range depending how long you spend at a traffic light. Even when stuck in heavy traffic it never goes over 203 before it starts down. So In my opinion you gain nothing with a 180. Maybe that's why you can't find them. BTW the best tunners in the country for these motors all use 160 stats. Humm, wounder why????
andreas g.
Old Feb 23, 2006 | 11:15 AM
CYA-Vett's Avatar
CYA-Vett
Most people forget that thermostat temperature ratings are for the coolest temperature it will open. A 160 stat will run barely any cooler if the fans do not come on earlier than stock.
The temperature rating is the coolest your engine will run, not the warmest, most people do not undetstand this.
Old Feb 23, 2006 | 11:19 AM
dollarbill's Avatar
dollarbill
St. Jude Donor '06-'07-'08-'09-'10-'11
160 or bust
Old Feb 23, 2006 | 07:37 PM
sallen619's Avatar
sallen619
What are the Oil Temps with the 160?
Old Feb 24, 2006 | 12:02 AM
LS1LT1's Avatar
LS1LT1
Old Feb 24, 2006 | 12:39 PM
andreas g.'s Avatar
andreas g.
Default oil temps
With a 160 stat on the highway the oil temps run 199-203 degrees. In city driving they range between 199-214 degrees. Both these temps are plenty hot enough to keep your motor clean. I went through an LS1 motor at 60,000 miles and it was clean like new inside. Ran a 160 stat its' entire life.
To 180 T'stat help, please
