Bad throwout bearing?
Old Feb 25, 2006 | 01:38 PM
Byrdguy's Avatar
Byrdguy
Default Bad throwout bearing?
When I push the clutch pedal ever so slightly, maybe a half inch, I get a faint whirring noise. Pedal pushed farther or full up, no noise. I also get some vibration through the pedal when shifting. Anyone else experience this? 2900 miles on the car.
Old Feb 25, 2006 | 03:41 PM
VET4LES's Avatar
VET4LES
It's probably normal. The throw out bearing is just resting all the way up and fully engaged when the pedal is down. When you move the pedal a small amount, the bearing is just starting to touch the pressure plate that is spinning when the engine is running.
Old Feb 25, 2006 | 03:42 PM
davidfarmer's Avatar
davidfarmer
under light load, the bearing is just spinning lightly, just enough to squeel. It might be a sign of future problems, but since it is quiet when loaded, it is probably fine.
Old Feb 26, 2006 | 12:01 PM
JmpnJckFlsh's Avatar
JmpnJckFlsh
David expressed my thoughts exactly...maybe not even a squeal; probably more like a faint rustling noise that goes away under full load. A future problem. Been there, done that...several times.
To Bad throwout bearing?
