Has anyone lowered only the rear of their C6 to just level the car? Pics? Thanx.
The car is designed to have a 5 degree rake for aerodynamic purposes. Of course if you're never going to drive it fast, I suppose removing the rake wouldn't matter much. Just be sure to get it realigned after you do it because changing the rake angle will change the suspension geometry.
yup, did it just for that reason....unfortunely i had the bolt turn all the way and it seems to only lower 1/16 inch. others on this forum had report as much as 1/2 inch lower. of course you could also cut the stock bushing to get it lower some more.
wow, you just answered a question that i have had for a long time, thanks. how low do you think the car can go with the lowering bolts without cutting the bushings?
are you asking about the stock bolts or the aftermarket lowering bolts? i didn't do the front, so i don't know....with the aftermarket lowering bolts i would say at least 1 1/4 inch. someone that has done it with aftermarket lowering bolts should be able to answer this one better then i can.
Wouldn't lowering the rear end also change the weight distribution too? My impression from GM's advertising of a "near perfect 50/50 F/R weighting" would lead me to believe that dropping the rear only would throw more weight that way and cause the car to handle differently.
Thanx for the input. I realized that the aerodynamics of a rear-only lowering job would change somewhat. I have the lowering bolt kit and will probably start with the rear-only approach, as I am concerned with the front scraping too much. If anyone has any hi-speed experience with a rear-only lowering job, sure would appreciate any comments on stability at speed. Thanx again.
Aside from the aero reasons:
Lowering only the rear changes the roll center in the rear and does not change the roll center in the front, leading to an increase in the understeer of the car. Google up "Roll couple distribution" to see how this works.
And of course, after lowering you still have to reset the suspension alignments for reasonable tire wear.
Lowering the rear does not change the position of the CoG longitudinally by more than a hundred microns or so and does not change the front to rear weight distribution by a measureable amount.
i guess it depends on how much you lower the rear. if you only lower 1/2 inch or so, i don't see how the rake angle is too much an issue. i know the rake is there because the car is capable of carrying some weight in the back. full tank of gas vs low on gas is a difference of 100lb or so plus it is reasonable to assume there could be a luggage weight of another 100 lb, maybe more. these 200 lb + variable will lower your rear weight some what.
