Speed, Pressure or Vacuum bleeding question
Old Mar 7, 2006 | 11:41 AM
AceVentura's Avatar
AceVentura
Default Speed, Pressure or Vacuum bleeding question
Speed, Pressure or vacuum bleeding? What do you recommend? Where to purchase?
One year old and I would like to perform a little pm.
Thanks!
J
Old Mar 7, 2006 | 01:14 PM
AU N EGL's Avatar
AU N EGL
Motive Power bleeder with GM cap. 10-12 psi
Vacuum bleeders tend to cavitate air at the bleed valve so your not really sure.
I personnaly never liked speed bleeders.
Useing the Motive with 12 psi, fresh fluid in the MC, a 10 mm wretch, old coke bottle with tygon tubing attached to the bleed valve a
crack open the bleed screw and the fluid just flows out. Wait until you see clear fluid and close the valve.
Old Mar 7, 2006 | 02:08 PM
davidfarmer's Avatar
davidfarmer
pressure! I use the GM cap and nitrogen, personally
Old Mar 7, 2006 | 02:52 PM
MitchAlsup's Avatar
MitchAlsup
Motive power bleeder here.
Old Mar 7, 2006 | 04:46 PM
AutoCutter's Avatar
AutoCutter
To Speed, Pressure or Vacuum bleeding question
