Great numbers. The heads and cam go into my C6 today and tomorrow. Friday Mike Norris will tune and dyno. Hoping for big numbers.
Jeff
Yes cant wait to see and hear it...Be going with almost the same setup as you... good luck maybe i will drive down there friday and see it run on the dyno..
That Is RWHP...You Mean Convert To FlyWheel? but either way i dont know...Should be like 15%-20% ..I would say around 430hp to the flywheel..maybe..Not really sure...
Just see this all the time and cant figure it out ?
For a stick divide by .85
For an auto by .80.
On a Dynojet.
These if you believe driveline losses to be 15% in the manual and 20% in the automatic. Some believe that driveline losses on today's cars are actually less than the 15% for manals and 20% for automatics.
With a Mustang dyno, I was told by a local tuner that one would divide .78 manual and .76 automatic to get engine HP.
