Voltage question
Old Mar 26, 2006 | 10:27 AM
scrannel's Avatar
scrannel
Originally Posted by timd38
If you keep discharging the OE battery, it will die becasue it wasn't designed to be deeply discharged and recharged repeatedly. The plates just fall apart when ypu take the battery apart. The Optima is more forgiving to that type of abuse.
It is an Optima and only partially discharged. Trying to determine why Priority Start always activating. My next, simple-minded test, will be to make sure battery is charged, remove Priority Start, and monitor voltage.
