Stainless steel break lines?
Old Mar 26, 2006 | 08:11 PM
1fastLT's Avatar
1fastLT
Default Stainless steel brake lines?
First off has anyone here done stainless steal brake lines? Is it worth doing?
Old Mar 26, 2006 | 08:13 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
I just did them when i put my z06 brake setup on and they seem to make the pedal firmer
I bought the stoptech setup
only $160
Old Mar 26, 2006 | 08:22 PM
sallen619's Avatar
sallen619
I like mine...I don't think it was necessary though.
Old Mar 26, 2006 | 08:29 PM
burtonbl103
i had to do it because the factory lines will not mate up to the z06 calipers
Old Mar 26, 2006 | 08:37 PM
The Garage Master's Avatar
The Garage Master
Try brake.
Old Mar 26, 2006 | 09:09 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Others have posted that the SS brake lines usually have teflon inside of them, which is more prone to kinking than regular brake line rubber, especially after a year or two There was a strong indication that SS was the way to go for a dedicated track car, but a street driver with occasional track use would be best served with the stock brake lines.
Spring Mountain runs the snot out of their cars and they stay with the stock lines. I plan to do the same, just like I did on my C5
Old Mar 26, 2006 | 09:13 PM
Miaugi's Avatar
Miaugi
Originally Posted by Triple Black C6
Try brake.
Old Mar 27, 2006 | 07:11 AM
AU N EGL's Avatar
AU N EGL
SS lines are the only way to go. Brake fade MAY be partially do to the stock lines expanding.
Old Mar 27, 2006 | 07:41 AM
6speedC6's Avatar
6speedC6
If your going to race or run driver Ed events It will help. If you drive it only on the street it is not necessary. You won't get your brakes hot enough on the street to worry about fade from rubber lines
Old Mar 27, 2006 | 09:40 PM
excessive81's Avatar
excessive81
understand spring mountian HAS to keep the car 100% stock. not put them on my car yet but on my bike made a HUGE diffrence in the feel and effort. went to one finger to use the brake even when hauling the mail. if they gave 50% of the diffrence they do on the bike they are worth the 150
To Stainless steel break lines?
