Oil Analysis
Old Apr 5, 2006 | 04:36 PM
xs650's Avatar
xs650
Originally Posted by black05c6z51
how much now one has mentioned the price for this service
If I understand your question, which I may not . It was about $20 last time I used it.
Old Apr 5, 2006 | 04:49 PM
PJinNJ's Avatar
PJinNJ
Default Use to judge oil
I've used it when figuring out how long the oil I use remains functional. The C6 oil wear algoritm is not valid when using extended drain oils, even Mobil 1 15K oil. So, it's the only way to know how many times I need to hit the reset button before really having to change the oil. I usually hit the oil mfg reccomended change time before the oil wears out. 25k or 1yr.
Old Apr 5, 2006 | 05:41 PM
booker's Avatar
booker
Originally Posted by CYA-Vett
I still don't see the point. Except people are willing to spend money on anything
Is a sloppy engine build coverend under warranty?
BTW, I'll analyze anyones washer fluid for $19.99
Dave, I would like to go into the washer fluid anaysis with you. In the 70's I had some long haul trucks. Oil was sent in to Shell at 150,000 and then at 250,000. I needed to know when to do an over haul.
Now let me make sure I understand what's going on here. I have 20,000 on the Vette so I decide to have the oil analyzed. The report isn't good so I take it into the dealership and demand a new engine.
They can't talk to me about my new engine because they can't quit laughing. Is that what this is? A BIG JOKE!
Old Apr 5, 2006 | 05:47 PM
glennhl's Avatar
glennhl
Couldn't agree with you more! So people actually spend more money on the analysis to determine when to change oil when it would have been cheaper to just change the oil! I think it's more of a curiosity thing.
Old Apr 5, 2006 | 05:50 PM
glennhl's Avatar
glennhl
Originally Posted by xs650
I check it about once a year. HIgh silicon once the engine has cleansed itself build residue is an indication of an intake system leak. I found a small one on my C4 that way.
With your background, I expect you know it, but for the others, If the copper and iron are rising along with the silicon, then they are probably rising because of an air leak in the intake system or a poor air filter.
You'll have to explain this one to me. At work if we get high iron or copper then we figure we are getting gear or bearing wear. High silicone would tell us we are either getting casting sand or we have the wrong o-rings (silicone instead of viton) and they are degrading. I'm not aware that inlet leaks or bypass of the inlet filter would actually get into the engine oil. I'm not saying it doesn't, but I don't understand how unless it blows by the piston rings.
Old Apr 8, 2006 | 12:21 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
One year I lost most of the gears in the automatic transmission of my Camaro when i was on a long and important road trip. GM fixed the tranny under warranty but it ruined the trip and wasted a fair amount of my money.
After that, I've had Blackstone do an analysis of my engine oil and trans fluid every Spring before starting my summer fun. That doesn't guarantee that I'll get advance warning of problems but it certainly ups the odds in my favor.
Old Apr 8, 2006 | 12:46 AM
glennhl's Avatar
glennhl
This makes sense. One question though, lets say you see some very high iron and copper, or some other element. Are you going to tear down the tranny or engine?
Old Apr 8, 2006 | 10:32 PM
Gearhead Jim
St. Jude Donor '13
Well, first thing I'd do is post the numbers here and see what the experts say!
After that, I'd make my decisions based on the idea that instead of a 1% chance that the car would take a dump on me, it was now a 50% (or whatever number) chance.
Since the car will be under warranty for a long time (GMPP extended warranty), I know they won't try to fix anything based on only oil analysis. But I might just start flogging it so it would break sooner and get fixed sooner.
Old Apr 8, 2006 | 11:20 PM
cthusker's Avatar
cthusker
Oil doesn't wear out in the conventional sense... I have some Class 8 equipment that logged over a million miles without an oil change using onboard oil filtration equipment. BTW.. it's very common in Europe where oil isn't a gift like here in the US. Off shore oil rigs use the technology because the cost of oil disposal is so high. Someday I believe all vehicles will be equipped with oil filtration devices. This will save millions of gallons of oil and greatly reduce disposal problems. We have oil analysis done on all our trucks because we do and have inframed majored them when a particular trend was proven. Better to fix it BEFORE total failure which cost big bucks replacing a diesel engine. Not so sure of the benefits on gasoline engines and probably won't do it for my new vette. It's a very interesting topic however...
Old Apr 9, 2006 | 12:05 AM
Wayne88's Avatar
Wayne88
I have to agree with that.
Old Apr 9, 2006 | 12:53 AM
glennhl's Avatar
glennhl
You mean you are not flogging it now? Why did you buy a Vette? ;-)
Old Apr 9, 2006 | 10:30 AM
mvcrash's Avatar
mvcrash
I always do an oil analysis on high performance cars just to see if there is any antifreeze in the oil. The reason is obvious, keeps an eye on head gaskets. The antifreeze gets into the oil long before you detect the leak yourself.
FYI: (not trying to be a wise guy here, just post some info)
Silicon="tetravalent nonmetallic element that occurs combined as the most abundant element next to oxygen in the earth's crust and is used especially in alloys"<------THE REASON IT GETS IN YOUR OIL.
Silicone= "Any of a group of semi-inorganic polymers based on the structural unit R2SiO, where R is an organic group, characterized by wide-range thermal stability, high lubricity, extreme water repellence, and physiological inertness and used in adhesives, lubricants, protective coatings, paints, electrical insulation, synthetic rubber, and prosthetic replacements for body parts."
Old Apr 10, 2006 | 12:54 AM
  #33
glennhl's Avatar
glennhl
I've had high performance cars for 35 years and have never had a head gasket go bad.
Old Apr 10, 2006 | 12:02 PM
  #34
mvcrash's Avatar
mvcrash
To each their own. If you don't agree, don't have your oil checked. Never is a long time.
Old Apr 10, 2006 | 12:06 PM
  #35
catbert's Avatar
catbert
Never had a GTO huh!
Old Apr 10, 2006 | 12:16 PM
  #36
cranky's Avatar
cranky
after 25 years of fleet maintence experience, it is well worth getting your oil sampled. especially after the warranty goes out.............crancky
Old Apr 10, 2006 | 05:32 PM
  #37
glennhl's Avatar
glennhl
No GTO, but my first car was a year old 1968 Firebird 4 speed with the 400. Never had a head gasket go, but the one person was right, never is a LONG time.
I just get a kick from everyone spending their hard earned money on oil analysis. It will catch a bad head gasket, that was the best argument I've heard yet, but seeing high copper or iron is not going to force very many people to actually tear down the engine, it's just going to make them worry!
To Oil Analysis
Old Apr 10, 2006 | 07:11 PM
  #38
AutoCutter's Avatar
AutoCutter
Head gasket blown in a 350 chevy & 3.8V6-just luck of the draw!
I could see checking the oil once a year or so, but also the anti-freeze too as sometimes a blown headgasket shows up as oil in the anti-freeze. Of course, the dealership will laugh at the test results as the basis of warranty work.
Old Apr 16, 2006 | 11:34 AM
  #39
mvcrash's Avatar
mvcrash
GTO head gaskets were made of cheese I think. Replaced them for friends many times.
Trying to convince my daughter to attend ASU. SUN DEVILS!!!!
Old Apr 16, 2006 | 03:02 PM
  #40
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
i can see doing this with large truck engines where it takes 48 quarts to fill the crnkcase,are diven many miles between changes and the engines are very expensive. with a new corvette engine the chances of having a problem are slim to none so i just spend my money on the oil changes. GM is not going to warrant a engine repair on the showing of a oil analysis, they will wait till it fits their criteria for needing a repair. JMHO
