I remember reading somewhere on CF about sending oil samples out for analysis. They checked for different items like metals that showed bearing wear, silicone content, gasket material etc. Has anyone done this; if so would you do it again, and what company did you use?
I believe many are using Blackstone Labs. I sent in my first sample a week or two ago and am awaiting results. I made an initial change at 2,230 miles.
Blackstone for me too. Just sent it last week, so I'm waiting for my results too. There was a post on here, a few months ago, with a copy of an analysis.
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Blackstone is well respected on BITOG. IF you get a suspicious oil analysis, have Terry Dyson do a read on the analysis. You can use this URL to get the info on a dyson analysis, http://bobistheoilguy.com/terry.html
Terry's a good guy. He will also answer questions after you get his report. You really get your money's worth from Terry.
I received my oil report from Blackstone Labs today if you are interested in how their report looks.
This report is for what car? Report says LS1, 5.7... but you have a C6, right? Just a typo maybe? Just curious.
Thanks for posting the Blackstone report. As I suggested here at the forum a while back, it would be neat if there was a thread in the FAQ that merely included all members' Blackstone reports... would be interesting to compare. I plan to run a Blackstone oil test soon and will definitely post the results.
Just curious. WHY ?
Your oil samples are used to determine what ? Developers use sampling to determine fuel dilution, coolant leaks (glycol burns off), oil life and wear metals, to predict iminent failures. But, to give justice to your sampling how did you take your sample ? From your oil change bucket ?
Silicone content is extremely low these days since it contaminates O2 sensors, most of our seals on the LS2 are now carrier. Oh, and there are no sand cast LS2 components... Your represented oil analysis provides little value, very basic analysis performed on fleet vehicles.
One thing his analysis tells us is that there is lot of silicon in his oil, most likely from a sloppy assembly job. Hopefully it's from excess sealant and not dirt.
The high metal levels also show that the engine is throwing off wear metals at a moderately high rate as it breaks in.
If he followed Blackstone instructions he most likely caught it midstream as he drained the oil.
This particular report suggested that copper, lead and silicon were high... everything else considered ok.
I feel that periodic oil analysis tests are an excellent way to monitor an engine's internal condition. It would be interesting to determine the averages for the LS2 specifically, so I am interested in seeing more Blackstone reports for LS2s.
We do oil analysis (SOAP) at work on aircraft parts to look for trends. However, I've never done them on my cars. You can use a SOAP to either determine how much longer the oil will last or to determine how your engine is wearing. I change my Mobil 1 every 5,000 miles so I don't need to use it to determine the oil condition. I also don't do it because what if I do see the copper or iron or something else continue to rise. I'll just worry about it because I really doubt if I'd tear down an engine due to a poor oil analysis.
My results may be skewed by my taking the sample from the oil filter. I failed to fully RTFM until it was too late.
They could be, but with your low mileage, there are a high level of wear metals in the oil from the engine finishing the factory machining job as you drive it. It's also cleaning itself of excess sealant and who knows what else left in it when it was built, so the results are of general interest only.
It' still a good thing to do. If you take a few more samples at future oil changes, you'll get to see how much the wear metals in the oil decrease as your engine breaks in and cleanses itself of the stuff the factory left in it.
I check it about once a year. HIgh silicon once the engine has cleansed itself build residue is an indication of an intake system leak. I found a small one on my C4 that way.
Some people find that they have coolant leaks into the engine by oil analysis before there are obvious other signs. I don't think the LSx engines have internal leakage problems, but some GM engines are famous for them.
With your background, I expect you know it, but for the others, If the copper and iron are rising along with the silicon, then they are probably rising because of an air leak in the intake system or a poor air filter.
I still don't see the point. Except people are willing to spend money on anything
Is a sloppy engine build coverend under warranty?
BTW, I'll analyze anyones washer fluid for $19.99
I still don't see the point... people are willing to spend money on anything.
Doing oil tests on a new C6 may or may not ultimately help one preserve the engine.
I think for many of us, doing something like testing oil is just part of the ownership experience... fun and interesting. That's what makes this a hobby. Some owners love to spend hundreds of hours waxing the paint... if that makes 'em happy, by all means they should do it. Others, like me, hate waxing paint, but instead like to spend their free time and extra bucks studying mechanical issues... like testing and graphing oil quality, etc. At the very least, it's educational and entertaining... and thus worth it.
Let's face it, most of us car guys are a little nutty. Paying a few bucks for an oil analysis now and then is certainly one of the lesser car-guy "offenses".
