out side temp
Old Apr 1, 2006 | 05:16 PM
shw time's Avatar
shw time
Default out side temp
My temp for the outside is reading 119-123 when it is only like 60 outside anyone have this problem before? Where does the temp pick it up from? Could it be touching something under the car?
Old Apr 1, 2006 | 06:40 PM
LS WON's Avatar
LS WON
Sensor is located somewhere near the front bumper perhaps your car is running a fever.
Old Apr 1, 2006 | 07:10 PM
xs650's Avatar
xs650
Were you parked when you got the high reading? It takes awhile after you start moving before you get good readings.
Old Apr 1, 2006 | 07:38 PM
Vette_DD's Avatar
Vette_DD
You probably have a problem that someone needs to look at. Here's what the 05 owner's manual says on pages 3-27 and 3-28.
There is also a sensor located behind the front bumper.
This sensor reads the outside air temperature and
helps to maintain the temperature inside the vehicle.
Any cover on the front of the vehicle could give a false
reading in the temperature.
If the outside temperature goes up, the displayed
temperature will not change until:
• The vehicle’s speed is above 10 mph (16 km/h)
five minutes.
• The vehicle’s speed is above 32 mph (52 km/h) for
two and a half minutes.
These delays prevent false readings. If the temperature
goes down, the outside temperature will be shown
when you start the vehicle. If it has been turned off for
less than three hours, the temperature will be recalled
from the previous vehicle operation.
Old Apr 1, 2006 | 08:33 PM
EuroRod's Avatar
EuroRod
Damn, thats complicated. I had a PepBoys outside thermometer ($10) that worked for 15 years and was always within a degree or two of the broadcasted temp. It was still working when I sold the truck. Never changed the battery! Of course, it wasn't hooked to any kind of ac system for a reference or anything hi tech, but it worked!
Old Apr 1, 2006 | 08:38 PM
VET4LES's Avatar
VET4LES
You can see the sensor. It's under the hood on the right (passenger) side up front next to the radiator down low with a wire coming from it.
Old Apr 12, 2006 | 03:40 AM
LS WON's Avatar
LS WON
That is sort of like getting one of those compasses for $2.00 just stick it to the glass don't have to worry about any bulbs or anything else going out or draining any current.
Old Apr 12, 2006 | 07:18 AM
C8-Vette's Avatar
C8-Vette
Never changed sensor on my C6, but did so on my wifes Olds. If I recall price for sensor was under $10 and it snaped in and out.
To out side temp
