Camshaft Install Question
The JPR tool holds up the lifters without fear of any of them falling.
You need a tool to press the balancer back on
You need a good spring changing tool
And you need a hose to screw into cylinders to hold up the valves while you change the springs. (Hopefully you have an air compressor)
Yes, you can do a cam swap without ANY of the mentioned tools but it's a whole lot easier with them. However, there are substitutes for most of them and many people use them, I use substitutes myself sometimes, but having the correct tools is half of the battle, especially if its your first time.
I've never used the timing cover tool, as long as you install the balancer quickly and don't tighten the cover until the balancer is fully seated, the tool is not necessary.
The 5/16th rod is simply a crude version of the JPR tool. I've used both, but the fit needs to be pretty snug. The rod you fabricate must have the side shaved off of it (the tool designed for this is not round), so basically you can only make it out of wood unless you can cut a perfect 2 foot line in a piece of steel. If the (wooden)rod expands at all while inside the motor, due or temp, oil, etc...you run the risk of it snapping off inside while inserting or removing it. It's probably a longshot that it would happen, but why risk it? Again, both methods work. One is cheaper, but the other safer. You can also use 16 pen magnets to hold up the lifters, or instead of a wooden rod, some guys have used a 5/16 rubber fuel line. You can use tricks, but my goal was to make it easier for everyone.
Yes, the rods slip in through the front of the engine and run the length of the block.
Dave
The LS1 is 99% the same as the LS2 so you can look here for full instructions.
Don't get scared, it's faily easy to swap a cam. If you get stuck, we'll help you out...
My first cam swap took me the better part of a weekend, now I can do them in less than a day. Good Luck
Dave
